91 integra?
91 integra?
2 ?'s....what do i have to do to put the seats from a 91 teg ls into my 98 ex coupe and would it be easy to swap the auto tranny and b18b into my auto ex?
Re: 91 integra? (siqcivic)
You need to swap the rails over (the easiest way) and even still they won't on there properly as EG/DC/EK seats are wider on the base but you can make them fit with some customizing. Basically same thing I ran into when putting JDM ITR Recaro seats into my 91 Integra.... if you drop them in as is, only 2 (in most cases) of the holes will line up.
senior gold member
Re: 91 integra? (95excoupeMT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupeMT »</TD></TR><TR><TD CLASS="quote">the motor would not be an easy swap due to its cable clutch...and the motor from a 91ls is B18A...B18B is 94+</TD></TR></TABLE> he said auto. and to answer your question. the mount thats welded on the frame of the teg is different but I'm not positive. I would just find a newer engine and auto trans out of a 94 and up.
Re: 91 integra? (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan »</TD></TR><TR><TD CLASS="quote"> the mount thats welded on the frame is different but I'm not positive.</TD></TR></TABLE>
On an EK Civic, they're all the same (engine bay layout). There's no "bracket" that sticks out on the framerail like an EG/DC engine bay. On the EK Civics, a brackets bolts up to the framerail so you can use either an auto or 5-spd chassis as they're the same in the engine bay.
I have tried to use 91 teg seats in 92 up civics and they never fit right. I know newer teg seats bolt in but you will run into some issues with the bolts lining up.
ebp_dc2
01-14-2006 04:39 AM
