Disable ATTS in 5th gen Prelude SH.
Old Sep 6, 2001 | 09:07 AM
97LudeSH's Avatar
New User
Default Disable ATTS in 5th gen Prelude SH.
Hey,
I was wondering if there was any possible way to disable ATTS in our 5th gen's.
It robs about 5hp, 5ft/lbs of torque at the wheels.
I want to be able to disable it for 1/4 mile runs, every bit counts.
Is there a fuse that could be pulled, or is it even possible, easily?
Thanks,
Mike
Old Sep 6, 2001 | 09:19 AM
JinMTVT's Avatar
New User
Default Re: Disable ATTS in 5th gen Prelude SH. (97LudeSH)
i don't think u will regain the power by disabling it..
cause from what i konw..it's the fact that the power as togo through it thatmakes u loose some power at the end..
not because is it ON ..
like if u would have to go trhough 2 trannys in a row..u would loose a lot of power cause of that ..
Old Sep 6, 2001 | 09:40 AM
97LudeSH's Avatar
New User
Default Re: Disable ATTS in 5th gen Prelude SH. (JinMTVT)
I actually never really thought it through.
That makes perfect sense and you're probably correct.
Thanks,
Mike
Old Sep 6, 2001 | 10:57 AM
ZygSpeed's Avatar
There might be a fuse you can pull.
Check your owner's manual.
Old Sep 7, 2001 | 02:41 PM
fixhondas's Avatar
Default Re: Disable ATTS in 5th gen Prelude SH. (zygspeed)
Disabling it wont gain you anything- the loss is from the atts unit being the final drive and bieng part of the driveline.
.jacob
Nov 29, 2008 03:03 PM
caliskier
Feb 1, 2008 07:49 AM
mathews
Oct 27, 2004 09:54 PM
ebayjackal1598
Sep 20, 2003 06:58 PM
