DC 4-1 header hangs too low!!
Old Sep 6, 2001 | 06:52 AM
dynomite55's Avatar
New User
Default DC 4-1 header hangs too low!!
I have a 99 Civic Si with DC 4-1 headers. I bottomed out two days ago and hit the header on the ground. The #1,3 tubing got dented on the bottom. Is it alright to keep on using the header? Will it effect the car a lot? Please help. Thanks.
Old Sep 6, 2001 | 07:51 AM
rioninja's Avatar
Default Re: DC 4-1 header hangs too low!! (dynomite55)
You can take the header to a good exhaust shop, and they will be able to straighten it right out. If you cant find a place, shops that specialize in dirt bike pipes will be able to do the work as well.
Old Sep 6, 2001 | 01:58 PM
dynomite55's Avatar
New User
Default Re: DC 4-1 header hangs too low!! (RioNinja)
i have to take the header off to do that right? The header is ceramic coated...can they do that?
Old Sep 6, 2001 | 02:08 PM
rioninja's Avatar
I'm not to sure about the ceramic coating, but you might have a little problem. Honestly i dont know if they will be able to. I would call around and ask questions.
Old Sep 6, 2001 | 05:52 PM
dynomite55's Avatar
New User
thanks...but for now u think it's ok to drive around with 2 dented header tubes?
Old Sep 6, 2001 | 06:05 PM
6SPD_EK's Avatar
hey dynomite - is your car lowered at all? I have the spoon header and a lil weary to put it on cause I'm afraid of denting it (i'm at stock height). BTW you should be ok to drive, you might lose some hp though
Old Sep 6, 2001 | 08:32 PM
Tripz's Avatar
New User
Default Re: DC 4-1 header hangs too low!! (2000-4DRGSR)
Don't worry too much, i bottom out all the time, my DC 4-2-1 CC header has two fairly large dents in the down pipes, they're actually concaved inwards and pretty bad. i might have even picked up some torque! other than bottoming out and hitting them...i also scrape them up too...so the dents i got are pretty lenghty....they've been through alot but are flowing just as well.
Old Sep 7, 2001 | 12:07 PM
ANACC2NV's Avatar
New User
Default Re: DC 4-1 header hangs too low!! (Tripz)
humm i have the DC 4-1 and eibach sportlines on my GSR and i havent bottoned out yet , you just have to be carefull
broketuner-Sol_Si
Mar 20, 2006 10:57 PM
germanEE8
Nov 20, 2003 11:19 PM
3700 Vtec
Mar 24, 2003 07:38 PM
DaNish
11
Oct 8, 2001 04:14 AM
