Cooling fan wont turn on???
Old Oct 30, 2003 | 07:11 PM
eghatchproject's Avatar
Default Cooling fan wont turn on???
I have a 95 dx with an LS swap and my cooling fan wont turn on when the car gets hot. I replaced the relay and I know the fan works cause I plugged it into the a/c wiring. Anybody have any ideas?
Old Oct 30, 2003 | 07:12 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Cooling fan wont turn on??? (eghatchproject)
jump the fan switch. if it runs, replace the fan switch. brown switch on the tstat housing.
Old Oct 30, 2003 | 07:14 PM
Default Re: Cooling fan wont turn on??? (boostedcivicsir)
Thanks...how do I jump it? What do I use? I should've added that I had this problem before the swap on my DX motor and it's still happening on the LS motor
Old Oct 30, 2003 | 07:15 PM
Ricey McRicerton's Avatar
just run the wires directly to the battery. If it does'nt come on you found your problem.
Old Oct 30, 2003 | 07:18 PM
Default Re: Cooling fan wont turn on??? (Ricey McRicerton)
Would I need to splice into the fan switch wiring or can I use the little prongs on the plastic connector to go to the battery with?
Old Oct 30, 2003 | 07:22 PM
Mr. Badwrench
just unplug it, get a paper clip and jump the terminals on the harness side. and if it turns on, chances are you need a fan switch. and if not, iti s in that wiring. or where the fan is powered from there.
Old Oct 30, 2003 | 07:27 PM
well since this has happened with my DX motor and my LS motor it's probably in the wiring. When the car was running I noticed that I didnt put the fuse for the cooling fan back in and not thinking I put it in. The fan immediately turned on but after that it wouldnt turn on when the engine heated up/
Old Oct 30, 2003 | 07:31 PM
Pull the fuse one more time and see if it's blown. Sounds like a blown fuse to me now.
Old Oct 30, 2003 | 07:34 PM
The fuse was blown then I replaced it so their is a brand new fuse in there. Think I could've shorted it by inserting the fuse when the car was running? I've replaced the fuse since then and still nothing.
Old Oct 31, 2003 | 08:29 AM
hondasleeper's Avatar
Could it be your ECT sensor or switch has gone bad? I had the sensor go bad and caused the car to overheat when the car was idling but once it was moving everything was fine.
Old Oct 31, 2003 | 08:58 AM
VRD^don's Avatar
Default Re: Cooling fan wont turn on??? (hondasleeper)
same probelm happened to me. so i just wired it to a switch so when the car gets hot i just flip the switch ..
Old Oct 31, 2003 | 09:49 AM
Mr. Badwrench
Default Re: Cooling fan wont turn on??? (sohc_vtec)
food for thought. it take a bit for the fans to come on. run it at 2000 for a few. if it is not overheating, you are ok. but it does take a while for the fan to come on.
Old Nov 3, 2003 | 04:23 AM
VRD^don's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">food for thought. it take a bit for the fans to come on. run it at 2000 for a few. if it is not overheating, you are ok. but it does take a while for the fan to come on.</TD></TR></TABLE>
yes it does...thats how my car overheated...the fan never came on..
Old Nov 3, 2003 | 04:40 AM
mohater's Avatar
For now you seem in a hurry
just rig it with a positive wire to keep it running
Fans are pretty easy to come buy - so if you ruin the fan should be too hard to get a new one
just an accessory wire and hook up the positive wire on the fan relay to it
i did it to mine
worked great
monicle's Avatar
make sure you have your radiator filled all the way up as well as the reserve.
DrewBrews
Dec 23, 2011 09:59 PM
zeb1117
Apr 3, 2010 09:33 PM
kit50si
Aug 21, 2008 08:16 PM
wsiracerz
50
Jun 10, 2004 12:09 PM
notfastenough
Oct 29, 2003 07:39 AM
