Cost of Lower Balljoint removal from Honda?
Old Oct 30, 2003 | 07:01 PM
2000DX's Avatar
Default Cost of Lower Balljoint removal from Honda?
I just thought about doing this since my brother and I have tried everything to get the LCA off from the balljoint. In the process, we poked the boot to hell. I was wondering if anyone knows if Honda does it? and how much would it cost?
Old Oct 30, 2003 | 07:02 PM
ransack's Avatar
Default Re: Cost of Lower Balljoint removal from Honda? (00 Hatch DX)
way to much.
I took mine to GoodYear and for 20 bucks the pressed it out and put my new one in
Old Oct 30, 2003 | 07:04 PM
2000DX's Avatar
Default Re: Cost of Lower Balljoint removal from Honda? (ransack)
damn.....I think all the goodyear's closed down around here
Old Oct 30, 2003 | 07:57 PM
CXHatchback's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 Hatch DX &raquo;</TD></TR><TR><TD CLASS="quote">damn.....I think all the goodyear's closed down around here </TD></TR></TABLE>
Any tire/automotive service shop should do it. Allied, Tuffy's, Big Ten, Firestone...
Most will charge an hour's worth of labor. $20 is quite the deal.
Old Oct 30, 2003 | 08:29 PM
chillly's Avatar
Default Re: Cost of Lower Balljoint removal from Honda? (CXHatchback)
I wonder why it's giving you such trouble to come off...I just pressed in poly bushings a few weeks ago, and of course had to pull the LCAs off to do that too. I just got one of those forked ball joint pullers from AutoZone, stuck it in there, and it only took about two or three good pops with a hammer and it came right out...
But yeah, about an hour's labor sounds about right to me- somewhere between $40-$100 bucks, depending on the shops hourly rate.
Old Oct 30, 2003 | 08:43 PM
senpai's Avatar
Go to your local Autozone (or auto parts store) and rent/buy this:
I guarantee it will work
Old Oct 30, 2003 | 08:59 PM
ransack's Avatar
Default Re: Cost of Lower Balljoint removal from Honda? (maztur)
yeah 20 was nice
im like, I took it to 2 shops
one said they dont do that (????)
and the other failed to get it out
so goodyear tires here said, 20 bucks. im like KEWL.
I would try the press, but mine was nicely in there
Old Oct 30, 2003 | 10:00 PM
B and B's Avatar
Loved
Community Favorite
I thought I understood, but you're unclear.
Are you trying to replace the ball joint or just separate the knuckle and lower control arm for another reason?
Smacking the LCA itself while applying some downforce with a large pry bar will knock it loose from the knuckle. Hit it hard with a big hammer on the boss where the bj stud passes through. It works on the upper too, just hit the knuckle outside of where the stud goes through. It leaves a dented lca/knuckle (hardly noticeable) but an untouched bj boot.
DO NOT use one of those forks!!!!
Old Oct 30, 2003 | 10:26 PM
deviant1's Avatar
Default Re: Cost of Lower Balljoint removal from Honda? (B and B)
if you smack it to hell where you can tell its been smacked in, will anything happen to the LCA? will it crack there? im talking, where you hit it so much, its flat in that spot and the metal is kinda rippled up.
Old Oct 31, 2003 | 12:40 AM
leadfoot78's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">Go to your local Autozone (or auto parts store) and rent/buy this:
I guarantee it will work</TD></TR></TABLE>
I have one!! Yup it's a life saver.
Old Oct 31, 2003 | 04:41 AM
phantom_sol's Avatar
Default Re: Cost of Lower Balljoint removal from Honda? (leadfoot78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leadfoot78 &raquo;</TD></TR><TR><TD CLASS="quote">
I have one!! Yup it's a life saver. </TD></TR></TABLE>
sure beats using a pursuader and ruining the threads. unfortunately i had one of those adjustable ones, so it was a pain to fit it correctly and tighten it down so it wouldne slip off....
either way. better do it right the first time or you will have grief when the ball joints are all ruined.
but i think the topic is asking how to remove the actual ball joint itself. not seperating it from knuckle/lca
Old Oct 31, 2003 | 09:20 AM
D50boy's Avatar
Best tool I own.... next to my ****
Old Oct 31, 2003 | 10:25 AM
2000DX's Avatar
Default Re: Cost of Lower Balljoint removal from Honda? (D50boy)
I tried that Pitmann Arm Puller...didn't fit over the joint. I am trying to take the balljoint out from the knuckle to replace it AND trying to get the LCA off from the balljoint. Damn bastard doesn't want to budge. Oh well, I found a Goodyear near my house, after work i'm going to take it over there.
Old Nov 1, 2003 | 05:48 PM
Mista Bone's Avatar
D Tranny Guru
did you remove the lock ring from the ball joint??????
Old Dec 7, 2003 | 05:25 PM
crazy eyez killa
Guest
Posts: n/a
OK gentlemen I am in the process of removing my axles
I got the balljoint off the LCA but I tore the little jelly filled boot up,
Where can I get the boot and how do I replace it?
jisi
Northeast
25
Aug 31, 2008 04:58 PM
Kidnkorner
Classic Hondas
Jul 26, 2007 01:47 PM
lude98SH
Jul 12, 2006 01:19 PM
gezer
40
May 24, 2005 01:08 PM
