LS motor stroker kit?
What company makes the best stroker kit for a Ls bottom end and what are the prices on them.. Who makes the cheapest kit.. and what kind of power increase will i get from the stroker kit it self?
Re: LS motor stroker kit? (94blackhatch)
do you want a 2.0 LS block? you'd be wayyyyyy better off with a bigger bore. the R/S ratio is gonna be FUCKED up with a stroker kit on an LS block. plus stroker kits would go for 2 grand +
Re: LS motor stroker kit? (JUN EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 »</TD></TR><TR><TD CLASS="quote">do you want a 2.0 LS block? you'd be wayyyyyy better off with a bigger bore. the R/S ratio is gonna be FUCKED up with a stroker kit on an LS block. plus stroker kits would go for 2 grand +</TD></TR></TABLE>
Ok but what if i increased the bore and then stroked it to a 2.0?
also does anyone know the power diference between a stroked gsr compared to stoked Ls?
Re: LS motor stroker kit? (Turbo92cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo92cx »</TD></TR><TR><TD CLASS="quote">
if you bore it out to 2.0L with 84mm pistons then you don't need to stroke it. it would be cheaper and more efficient for an LS block.
Re: LS motor stroker kit? (Mar_EK)
about how much cheaper do you think it will be... I have found a stroker kit for the ls motor for 1300 so im guessing most kits are around that price. Also what kinda power diference would i gain from that over the kit and how much more efficent would it be?
