NEED HELP: Problem with gsr cluster in an ls
hi everyone,
i have a 94' ls and put in a 98' gsr cluster. everything works except the ABS light is always on and the gas idle is way below empty while im driving. but before i start the car the gas idle is in the right place.
also the back of the gsr cluster has a little chip on it which the ls doesnt, anyone know what its for?
thanks for your help
darren
darren
It's because the gsr cluster was from a 96+ car going into your 95 or under car.
The 3 wires are switched. The gas wire goes to the abs light, the sealtbelt wire goes to the gas gauge, the abs goes to the seatbelt light.
hth.
--reid
hth.
--reid
Yeah, you pull it out and swap the wires. I don't have a diagram but you can look at a friends wire harness in the back to line up the wires.
--reid
--reid
thanks again reid but what do i pull out? i need to fix this ASAP cause i dont know how much gas i have, lol
and do u know what that little chip is on the back, its the one that pops out
thanks again
darren
thanks again
darren
