Cluster Help
Old Oct 29, 2005 | 12:02 PM
crimson2k2's Avatar
Default Cluster Help
just put a ITR cluster in my car, but so far the gas gauge wont read, it goes to full...so would i have to put gas in my car to make it work right or whats the deal? also, there is a ABS light on, i dont have ABS, and I didn't see a bulb to pull out for it.
Old Oct 29, 2005 | 12:12 PM
alexuslisbeth's Avatar
Default Re: Cluster Help (crimson2k2)
about the abs light on, there must be a bulb in the back of the cluster, just look at the right hole for the abs. with regards to the gas gauge, well i would recomend u to open the clear glass out and set it to empty then let it run with the car on. let me know if it works.
Old Oct 29, 2005 | 12:15 PM
rufridn's Avatar
i think the ITR cluster is wired differently. i wish the search worked.
Old Oct 29, 2005 | 12:19 PM
crimson2k2's Avatar
Default Re: Cluster Help (alexuslisbeth)
well i looked at the bulbs and didn't see one for the abs....so i had no luck there....i was just told by someone to try settin the gas to empty, so i'll go try that.
Old Oct 29, 2005 | 12:24 PM
rufridn's Avatar
this is from a post on team-integra.net . they say to swap all the stuff into your oem cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">problem fixed!
i swapped everything like some people have suggested.
i swapped the faux cf bezel surround & all the itr gauges to my stock 94 cluster essentially utilizing the green electronic film & housing from the usdm 94 cluster.
i didn't swap the plastic color pieces that show the seatbelt, ebrake, etc. do i have to do that as well?
i compared the jdm itr to my usdm and everything matched up perfectly from what i could tell.
that orange/red glow & yellow needles on the jdm cluster light up nice. i'm not into the fad about getting jdm just because it's jdm but i must say we were cheated on the cluster!
i will find out tonight if the gas gauge is fixed or not while i drive around more.
thanks everyone for their help.</TD></TR></TABLE>
Old Oct 29, 2005 | 01:20 PM
crimson2k2's Avatar
Default Re: Cluster Help (rufridn)
ok, but buy doin this I assume I will have to remove the needles, and someone told me that I shouldn't do that.
Old Oct 29, 2005 | 04:25 PM
ernald711's Avatar
Default Re: (rufridn)
i guess you missed the memo on adjusting your fuel qauge to match yours before the install.
Old Oct 29, 2005 | 06:25 PM
2uy
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crimson2k2 &raquo;</TD></TR><TR><TD CLASS="quote">just put a ITR cluster in my car, but so far the gas gauge wont read, it goes to full...so would i have to put gas in my car to make it work right or whats the deal? also, there is a ABS light on, i dont have ABS, and I didn't see a bulb to pull out for it.</TD></TR></TABLE>
to answer ur question switch the green film on the back of it and it should work
worked for me. had the same problem as u.
2KEXVtec
Jul 8, 2023 11:10 AM
utturkey
May 25, 2011 05:42 PM
LaEzEnT
Feb 23, 2006 09:56 PM
Beezle
May 24, 2005 10:01 PM
