NEED HELP: Problem with gsr cluster in an ls
Old Sep 6, 2001 | 12:41 AM
Darren94ls's Avatar
New User
Default NEED HELP: Problem with gsr cluster in an ls
hi everyone,
i have a 94' ls and put in a 98' gsr cluster. everything works except the ABS light is always on and the gas idle is way below empty while im driving. but before i start the car the gas idle is in the right place.
also the back of the gsr cluster has a little chip on it which the ls doesnt, anyone know what its for?
thanks for your help
darren
Old Sep 6, 2001 | 10:15 AM
Darren94ls's Avatar
New User
Default Re: NEED HELP: Problem with gsr cluster in an ls (Darren94ls)
anyone know what the problem is or have first hand experience with the swap
thanks
darren
Old Sep 6, 2001 | 03:15 PM
Akira-R's Avatar
It's because the gsr cluster was from a 96+ car going into your 95 or under car.
The 3 wires are switched. The gas wire goes to the abs light, the sealtbelt wire goes to the gas gauge, the abs goes to the seatbelt light.
hth.
--reid
Old Sep 7, 2001 | 12:08 AM
Darren94ls's Avatar
New User
Default Re: NEED HELP: Problem with gsr cluster in an ls (Akira-R)
thanks reid!
is there a way to fix it?
any other help would be great
darren
Old Sep 7, 2001 | 12:36 AM
Akira-R's Avatar
Yeah, you pull it out and swap the wires. I don't have a diagram but you can look at a friends wire harness in the back to line up the wires.
--reid
Old Sep 7, 2001 | 12:47 AM
Darren94ls's Avatar
New User
thanks again reid but what do i pull out? i need to fix this ASAP cause i dont know how much gas i have, lol
and do u know what that little chip is on the back, its the one that pops out
thanks again
darren
Old Sep 7, 2001 | 08:45 AM
Darren94ls's Avatar
New User
ttt ^^^
Fastasscar
May 7, 2009 09:16 PM
crimson2k2
Oct 29, 2005 06:25 PM
Obie_Ricee
Feb 15, 2005 08:34 PM
JeremyL
Apr 3, 2003 12:01 AM
