h22 engine problems....need help someone help me....
Old Oct 30, 2003 | 02:08 PM
gdrum's Avatar
Default h22 engine problems....need help someone help me....
Okay so i went to the track last night. I have an h22a in a 95 civic SI hb. bolt ons like i/h/e msd ignition that stuff. So I go and make about 5 runs. On the 5th run i bounce it off the rev limiter whatever that is. Its a usdm spec motor and ecu. So every run after that it bogs when i give it gas in 1st gear but then it revs up fine after i get outta the bog. So im like well maybe my plugs are bad...so today i go to change the plugs, all 4 plugs were like finger loose....so figured that was the problem..changed them to some bosch platnums and tightend them down good and put all the wires back on. It still does the same thing...bogs lil bit in each gear but after it gets over 1k rpms it takes off. I checked all the coil wires and stuff making sure there were good connections and there were. What could my problem be? Please help me....im scurrd somethign is seriously wrong with my motor. thanks
Old Oct 30, 2003 | 04:37 PM
gdrum's Avatar
Default Re: h22 engine problems....need help someone help me.... (gdrum)
anyone?
Old Oct 31, 2003 | 12:29 PM
gdrum's Avatar
anyone? bump it up
Old Oct 31, 2003 | 03:27 PM
99_SH's Avatar
Check fuel pressure. Also change the dist. rotor. Your plug wires are new and fresh?
Old Oct 31, 2003 | 05:00 PM
anthony campos's Avatar
It sounds like your fuel filter had same problems before with itr swap in ek
Old Oct 31, 2003 | 06:12 PM
gdrum's Avatar
Default Re: h22 engine problems....need help someone help me.... (anthony campos)
k ill change fuel filter...i check my wires they appear okay but i could be wrong.....any other ideas
Old Nov 1, 2003 | 08:45 PM
rob d's Avatar
Is your check engine light on? Have you reset your ECU?
Old Nov 5, 2003 | 10:57 AM
gdrum's Avatar
Default Re: h22 engine problems....need help someone help me.... (rob d)
bump for other ideas
KEVTI
Feb 19, 2013 01:37 AM
hmj88hb
Mar 14, 2007 04:53 PM
crfr230
Mar 11, 2007 05:48 PM
Awar318
Jun 13, 2004 12:34 PM
Akkord29
Jun 25, 2003 05:39 AM
