Strange noise at betwenn 2900-3000 RPM's. No IDEA!!
Old Oct 30, 2003 | 11:32 AM
92BlackSi's Avatar
Default Strange noise at betwenn 2900-3000 RPM's. No IDEA!!
I have had the car in the air and everything and ca't seem to find where this vibration comes from. It happens right at or right before 3000 RPM's. Sounds like a heat shield but it is not.
I am not sure where it could be rattling from. The whole exhaust seems to be fine.
Any suggestions would help.
Old Oct 30, 2003 | 11:39 AM
JDMlyfestyle's Avatar
Do u got a header? If so u might wanna check and see if all the bolts are TIGHT. that can be an annoying rattling
Old Oct 30, 2003 | 11:40 AM
CNY Hatch's Avatar
bad engine mount maybe?
Old Nov 1, 2003 | 02:37 PM
92BlackSi's Avatar
Stock header and the plate that protects it is off. Was making noise while on too.
Don't know about an engine mount but it only seems to happen when I hold the RPM's there or decellerate in that range.
Old Nov 1, 2003 | 02:45 PM
ramz7887's Avatar
Default Re: Strange noise at betwenn 2900-3000 RPM's. No IDEA!! (92BlackSi)
I have the same problem!! I have weird vibration noises. How do you tell if a mount is bad? Can you tell by looking?
Old Nov 1, 2003 | 04:06 PM
The Internet Tough Guy's Avatar
Default Re: Strange noise at betwenn 2900-3000 RPM's. No IDEA!! (ramz7887)
i have the same problem too!!! just started happening the other day.
if i rev it past 3 and let it drop, right as the tach passes over 3 it makes a really funny grinding / rattling noise. doesnt sound good. wtf?
Old Nov 2, 2003 | 06:17 AM
92BlackSi's Avatar
Damn glad I ain't the only one. Mine happens while moving AND at a stop. Not sure if a mount could make a metal clattering noise?
Old Nov 2, 2003 | 06:56 AM
mrbsponge's Avatar
You guys having this problem,do you have true cat back exhaust, or a custom bent job? Seems a lot of the custom bents ones people have trouble making and they rattle in that rpm range. Just a thought from some of the problems my customers have mentioned.
Old Nov 2, 2003 | 07:29 AM
Jimmy's Avatar
Global Moderator
Default Re: (mrbsponge)
I had the same problem.
Take a rubber mallet and safely tap your 'cat convt.' and if you here like a thing rattling in there is a good chance your 'cat convt' is shot. I have an apexi n1 catback on my 92 si hatch and I'am putting a header on next week and replacing my stock cat with either a hi flo cat or test pipe.I'm sure this should fix my problem
Hope you figure it out
Old Nov 2, 2003 | 08:21 AM
CooBlueDAB's Avatar
Default Re: (USDMDC2)
I had and have this problem, it was cause a hole in the exhaust began to form. The vibrations from the hole made all kinds of wierd sounds.
Old Nov 2, 2003 | 09:42 AM
slowdx's Avatar
Default Re: (CooBlueDAB)
every honda i have had or driven stock or not has had this damn rattle that sounds like a heatshield is loose. I have cut off all my head shields and welded my header to downpipe on my stock gsr header and it sitll does it, i just gave up. One day when im rich ill get a new heaer, cat and exhaust and it will be gone haha.
Old Nov 2, 2003 | 10:35 AM
dwnthehatch's Avatar
Default Re: (slowdx)
I have the same problem. It's my cat.
Old Nov 2, 2003 | 10:44 AM
Default Re: (dwnthehatch)
hmm maybe ill check my cat. i have a stock exhaust so i dont know why this is happening. i think this calls for open header all the time .
anybody else know what would cause a wierd grinding / rattling noise at 3000rpm?
Old Nov 2, 2003 | 11:21 AM
bOOsTiNSoHcVtEc's Avatar
Default Re: (jwn7)
i have the same prob too but it happens at like 2700-2800 and if i hold it there its pretty loud...im wonderin if it really is the cat
Old Nov 2, 2003 | 11:53 AM
tvrsir's Avatar
Default Re: (bOOsTiNSoHcVtEc)
if you guys have this rattle and it not a heatsheild this is what it is. FROM 2500 3500 WHEN REVING AND LET THE RPM DROP YOU HERE A RATTLE SOMETING THAT SOUNDS LIKE TWO HOLLOW CAN RUBBING THAT YOUR A PIPE THE ONE RIGHT AFTER THE EXHAUST MANIFOLD AND RIGHT BEFORE THE CAT. IT'S RATTLING INTERNAL NOTHING YOU CAN DO BUT TO REPLACE WITHA NEW ONE OR AFTERMARKET HEADER.
Old Nov 2, 2003 | 12:15 PM
Shawn C's Avatar
In The Garage
capslock is your friend
Old Nov 2, 2003 | 03:20 PM
tvrsir's Avatar
Default Re: (ShadyED9)
i was trying to get evryones attention so you don't miss the answer to all their questions.
Old Nov 2, 2003 | 03:27 PM
Default Re: (tvrsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvrsir &raquo;</TD></TR><TR><TD CLASS="quote">IT'S RATTLING INTERNAL NOTHING YOU CAN DO BUT TO REPLACE WITHA NEW ONE OR AFTERMARKET HEADER.</TD></TR></TABLE>
do you know for sure (from experience) that is the problem? (sorry im not questioning your knowledge, i just want to be *sure* before i go rippin **** up)
what the hell causes this?
Old Nov 2, 2003 | 10:15 PM
RabbittZ's Avatar
i just had the same problem.. dont know how hard you looked at your exhaust.. but check out all the welds that run along it..start from the top where the engine is and look all the way down..
mine was in the middle of my car.. it was a bracket that held up the piping. it split and would rattle like crazy..just got it welded back together and its fine now... but yeah check all brackets or "resting spots" for the piping and youll prolly find your problem. haha ill try to take a pic if i can ...
Old Nov 2, 2003 | 11:12 PM
Default Re: (RabbittZ)
i havent even looked at it yet. football = lazy.
thanks ill check all that **** out.
Old Nov 3, 2003 | 04:21 PM
92BlackSi's Avatar
I just kept banging the **** out of the exhaust in hopes of hearing anything but nothing so far. I think a high-flow cat is in order anyway.
Old Nov 7, 2003 | 05:48 PM
tvrsir's Avatar
Default Re: (jwn7)
i'm postive there's even a bulletin on 97 integras for this a pipe problem.
Old Nov 7, 2003 | 06:36 PM
HATCHingMN's Avatar
Default Re: (92BlackSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92BlackSi &raquo;</TD></TR><TR><TD CLASS="quote">I just kept banging the **** out of the exhaust in hopes of hearing anything but nothing so far. I think a high-flow cat is in order anyway. </TD></TR></TABLE>
So..you cant tell where the noises are comming from?
My 92 SI is making metal vibration noises from the exhaust canister!! its hitting the heat shield above!!
Old Nov 7, 2003 | 06:53 PM
PRcivicHB's Avatar
Default Re: (HATCHingMN)
My 92 hatch does that as well.... but only between 2800 and 3000 rpms... besides that, it is quiet... i learned to live with it... althought the ladies think my car is falling apart....
Old Nov 7, 2003 | 07:14 PM
HATCHingMN's Avatar
Default Re: (PRcivicHB)
oh **** ...just like me..everytime I turn around the corner it rattle like hell...I think I have all the ladies head turns!!
93egsir
Jun 7, 2007 12:51 PM
Mike banX
Suspension & Brakes
May 17, 2005 04:37 AM
RSVTECDC4
Mar 17, 2004 08:19 AM
Hybridize
Oct 1, 2003 09:55 AM
WeSsCyDeR
Mar 10, 2003 03:48 PM
