VX problems
Old Oct 30, 2003 | 09:11 AM
WeeMan's Avatar
From: Put it in..Take it out... Put it in..Take it out, United States
Default VX problems
i had a 92 VX and i swapped a GSR into it... well i gave the vx engine to a friend of mine and he has a 92 cx... well its all in and everything but it wont run right... i noticed on my car there is a black box on the firewall that vac. lines come out of it... his doesn't have that box.... does he need it or is there a way around it????...
Old Oct 30, 2003 | 09:26 AM
melfice_mx's Avatar
Default Re: VX problems (EGizzleC1)
inside that box its the EGR solenoid, you don't need it with the GSR swap...
and your friend will need it to pass the smog check..
Old Oct 30, 2003 | 09:35 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: VX problems (melfice_mx)
make sure the engine is grounded. it won't start if it's not. not having the vac lines would not cause the engine to not start.
Old Oct 30, 2003 | 09:46 AM
BatuKing's Avatar
Yup you will need to install that control box for the EGR thats prob why it doesnt run right.. If your using the VX ECU on that motor you should get a code 12
Old Oct 30, 2003 | 11:34 AM
WeeMan's Avatar
Default Re: VX problems (BatuKing)
Would that box cause the car to studder when on the gas? (if its not there)
Old Oct 30, 2003 | 12:27 PM
civicminded92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGizzleC1 &raquo;</TD></TR><TR><TD CLASS="quote">i had a 92 VX and i swapped a GSR into it... well i gave the vx engine to a friend of mine and he has a 92 cx... well its all in and everything but it wont run right... i noticed on my car there is a black box on the firewall that vac. lines come out of it... his doesn't have that box.... does he need it or is there a way around it????... </TD></TR></TABLE>
He needs it - EGR stuff.
He also needs the P07 ECU and the 5-wire expensive-as-a-golden-******** wideband oxygen sensor. He will have to rewire for this to work...
Old Oct 30, 2003 | 02:20 PM
WeeMan's Avatar
Default Re: VX problems (civicminded92)
He also has a p05 ecu runnin it.... could that be a reason why its not running well
Old Oct 30, 2003 | 02:56 PM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGizzleC1 &raquo;</TD></TR><TR><TD CLASS="quote">He also has a p05 ecu runnin it.... could that be a reason why its not running well
Uh.. yea theres your problem
eggie75
Jan 20, 2005 06:07 PM
hondarookie10
Nov 5, 2003 11:34 PM
VTEC_warrior94
Sep 21, 2003 08:25 PM
bobbysteelz
17
Jul 20, 2003 10:10 PM
AdamITR
Feb 14, 2003 09:57 PM
