turbo mini me in a vx hatch
I have a spare d15, and a z6 head, and i was going to swap it in to the vx, wil i need a new ecu, or can i run the vx ecu?? also would i have to wory about the wiering of vtec, since the vx comes stock obd1? and will i need to keep that black box that is bolted in the middle of the fire wall? thanks
Risky Business
Re: turbo mini me in a vx hatch (VTEC_warrior94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_warrior94 »</TD></TR><TR><TD CLASS="quote">I have a spare d15, and a z6 head, and i was going to swap it in to the vx, wil i need a new ecu, or can i run the vx ecu?? also would i have to wory about the wiering of vtec, since the vx comes stock obd1? and will i need to keep that black box that is bolted in the middle of the fire wall? thanks</TD></TR></TABLE>
Yes you will need a P28. No, since your car has VTEC-E already, I dont THINK you will have to wire it up. What black box?
Re: turbo mini me in a vx hatch (BauleyCivic)
thanks for the reply, in the middle of my firewall there is a black box with 3 wires coming out of it, me or my friends could not find out what it was, but i sen the same thing on another vx hatch. Will the mini me turbo setup last more than 2000 miles? and also do you think its worth it to even do the mini me or just run non vtec turbo d15?
Location: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_warrior94 »</TD></TR><TR><TD CLASS="quote">thanks for the reply, in the middle of my firewall there is a black box with 3 wires coming out of it, me or my friends could not find out what it was, but i sen the same thing on another vx hatch. Will the mini me turbo setup last more than 2000 miles? and also do you think its worth it to even do the mini me or just run non vtec turbo d15?</TD></TR></TABLE>
what the hell is this guy talking about black boxthe only to black things i have seen in the middle of the fire wall is a map sensor but thats on dx models and that chacol canister thing but it has no wires and a evap purge valve
Risky Business
depends on how much boost you run...if you run 4-5 it'll last a while...if you run 8-10 it will probably blow up in the near future...you should be in good shape just keep it low boost
Re: turbo mini me in a vx hatch (streetdreams02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetdreams02 »</TD></TR><TR><TD CLASS="quote">
what the hell is this guy talking about black boxthe only to black things i have seen in the middle of the fire wall is a map sensor but thats on dx models and that chacol canister thing but it has no wires and a evap purge valve</TD></TR></TABLE>
He is talking about the black box on the center of the firewall. I don't think you need it. I removed it when I did my GSR swap in my VX.
Re: (b16a ferio)
Yah the black box is gone after a swap...mine is gone, the lil 3 wires harness n plug is just hanging there.....however there is an emissions standard for it...one of the vacumn lines off of it run the the evap canister returnv valve and it has to be connected......
I got hassled about it at my last emissions trip.....I BS'd my way through, thank god for az and its lazy *** non car knowing HS grads that test our cars....
