Odd clicks when starting
Old Oct 30, 2003 | 05:39 AM
jolt-tsp's Avatar
Default Odd clicks when starting
I'm thinking this is my starter relay, but when I try to start the car it makes a few really quick clicking sounds from under the dash near the ECU. I can't jump start it. I think I can roll start it, but the engine was cold and it's on a flat surface so my one attempt at that exhausted me and wasn't successful. Does that sound like relay is bad, or just a weak battery? I figure it isn't the battery since the lights come on pretty bright and the jump starting didn't help. When I take out the fuse for the starter it doesn't make the sound anymore. Any info would be appreciated.
Old Oct 30, 2003 | 06:23 AM
Spade's Avatar
Default Re: Odd clicks when starting (jolt-tsp)
Weak battery.
Your hearing the starter attempting to turn the flywheel but it doesn't have enough AMPS to put it.
Old Oct 30, 2003 | 06:27 AM
jolt-tsp's Avatar
Default Re: Odd clicks when starting (Spade)
Even though jump starting it didn't work?
Old Oct 30, 2003 | 06:29 AM
Spade's Avatar
Ah well.....no.
I'd start checking the relay like you thought.
Old Oct 30, 2003 | 07:50 AM
MrEg's Avatar
kinda sounds like you narrowed it down to the starter...try changing it....gl
Old Oct 30, 2003 | 08:04 AM
jolt-tsp's Avatar
Default Re: (mr_timluu)
Alrighty, I have an extra one of those in the garage, I'll give it a shot tonight.
Old Oct 31, 2003 | 04:20 AM
jolt-tsp's Avatar
Default Re: (jolt-tsp)
I replaced my starter yesterday, but no luck. I kept hearing those clicks. My friend also told me to check for weak battery one more time, so I took the battery out of me other car and tried it out, after trying the jump start again, but still no success. So now I have to spend $50 on a little peice of plastic with a few transistors on it to try that out.
Old Oct 31, 2003 | 04:17 PM
MrEg's Avatar
damnit i dont have my helms today....help this guy out!!! bump
prowheelie92
Acura TL, RL & ZDX
Jul 11, 2012 06:26 PM
inaety
Jun 24, 2011 12:57 AM
patrickstar
17
Aug 4, 2009 07:52 PM
almostjdmeg
Jan 15, 2009 04:57 PM
Accord15
Feb 20, 2003 02:16 PM
