master cylinder swap
Old Oct 29, 2003 | 08:46 PM
delux247's Avatar
Default master cylinder swap
ok i used the search and found nothing that helps so ill ask here
im trying to put a 1" GSR master cylinder in my RS integra but one of the brake lines isnt the right size(to small) what do i need to do to accomplish this swap
thanks
Old Oct 31, 2003 | 05:00 AM
delux247's Avatar
Default Re: master cylinder swap (egcivicturbo)
does anyone know???
Old Oct 31, 2003 | 06:13 AM
StyleTEG's Avatar
I am guessing the fitting is too small?
You will probably need to get that entire brakeline from a GSR. I think AutoZone sells unbent brake line for cheap, but its going to be much easier just to pull one off a junked GSR.
Old Oct 31, 2003 | 06:30 AM
SleepyEG's Avatar
Default Re: master cylinder swap (StyleTEG)
There isn't really a good solution. When I swapped my B18C1 into my EG....I put in the GSR master cyl. and the EG brake lines didn't fit...so I had to cut the end off the line, pull that fitting off, put a GSR fitting on, and flare the line out. Which isn't a good way to do it unless your comfortable with a flaring tool!
Old Oct 31, 2003 | 10:19 AM
R6Boy69's Avatar
you should look into getting a metric adapter... i know they have them for standard sizes... i ran into this to when i swapped my master cylinder... i just went to the junkyard and cut the fitting off and then flared the line.
Old Nov 2, 2003 | 07:50 PM
dirty_d_cx's Avatar
Default Re: master cylinder swap (crXBoy69)
nope all wrong
you need to use a double flaring tool which makes the flare a double walled flare
the tool is found at pep-boys for 15.00 and is really easy to use
and also the fitting that you need is extremely hard to find
go to a junkyard and get a fitting off of a gsr or a 93-95 civic ex 4 door (i dont think that the 92 had the same ms and bb)
if you have any q's feel free to e mail me @ DirtyDan463@aol.com
alscrx
May 9, 2008 04:34 PM
underb00steg6
10
Mar 31, 2007 10:38 AM
Suprdave
Aug 4, 2001 10:04 PM
Suprdave
Aug 1, 2001 07:45 PM
Suprdave
Aug 1, 2001 07:37 PM
