first time replacing clutch
Old Oct 29, 2003 | 08:31 PM
HXvtec's Avatar
Default first time replacing clutch
well its fucked up. we took the tranny out no problem. pretty easy put the clutch in and throw out bearing (do u need to put a new pilot bearing in to??) pressure plate and friction plate. first it would go in gear. blead it, now works fine but the clutch is really soft and goes straight to the ground. also my ****** brakes dont work. am i a ****** idiot or something what the hell did i do wrong. oh and it also makes a rattle noise when in gear. SOMEBODY PLEASE HELP ME!!!!
Old Oct 29, 2003 | 08:40 PM
madman604's Avatar
your brake and clutch are not connected.
so work on 1 thing at a time
Old Oct 29, 2003 | 08:49 PM
HXvtec's Avatar
Default Re: (Turbo E)
yea but on one side i took the caliper off and found out u didnt have to. i have no idea why the brakes are to the ground
Old Oct 29, 2003 | 09:55 PM
fishnfst's Avatar
Bleed both systems again. Make sure the reservoirs are full. Two or three pumps on the pedal and you can suck it dry. Make sure you keep filling them as you go. You definitely have air in both systems. There might be something else wrong also but its hard to say without looking at it. Start with just bleeding your brakes and then your clutch master and slave.
Old Oct 29, 2003 | 09:59 PM
=GAME='s Avatar
Default Re: (fishnfst)
yea bleed both mc's. next time try doing one thing at a time.
Old Oct 30, 2003 | 10:40 AM
HXvtec's Avatar
Default Re: (O.G triple O.G)
all i did was the clutch i was doing nothin with the brakes. u have to slide the rotor back. thats all i did with the brakes.
russianswty
Jul 20, 2006 11:34 AM
kevpotts
Mar 3, 2006 06:23 PM
turbocivic0618
Oct 9, 2005 10:12 PM
BB6racer
Sep 1, 2005 10:48 PM
hellrsnCL
Aug 10, 2005 08:29 AM
