throttle cable/backet info question???
Old Oct 29, 2003 | 08:07 PM
sir2k's Avatar
Default throttle cable/backet info question???
I have a ITR manifold with a cable bracket that says P2T on it. The cable and bracket fits perfect, OEM fitting.
now I got a ITR throttle cable but it's too long, so I had to use a B20 bracket to RIG it.
Does anyone know if ITR cable is different then B16?? Or what is the code name on the ITR cable bracket?
thanks
Old Oct 29, 2003 | 08:48 PM
sir2k's Avatar
Default Re: throttle cable/backet info question??? (sir2k)
anyone?
I don't know what cable I had on my car before it broke. it's a ITR manifold on a 96+ civic coupe.
Old Oct 29, 2003 | 09:01 PM
sir2k's Avatar
I think the p2t bracket is for a 99/00si, which I think it's the same as ITR. Right??
thanks
Old Oct 29, 2003 | 10:40 PM
kinvid22's Avatar
You should have a bracket that says P72 or P73. I think it's the 72 for the type r...80% sure, u can get those at the dealer or go here http://www.acuraparts247.com
Old Oct 29, 2003 | 10:59 PM
sir2k's Avatar
Default Re: throttle cable/backet info question??? (kinvid)
thanks.
are there any other acura online parts site? maybe a closer one to CA? or cheaper deals?
Old Oct 29, 2003 | 11:19 PM
sir2k's Avatar
alright. nevermind. I solved my problem.
you have to use a ITR bracket if you buy a ITR thorttle cable
same as if you buy a B16 bracket you need the b16 throttle cable.
the b16 setup is $11 cheaper then the ITR setup. Works the same but just because it's got a different finish on the ITR parts and it's ACURA it cost more.
Another way for Honda to make more money
mister_ej2
Mar 27, 2008 08:17 PM
boostincoupe
Feb 17, 2007 04:41 PM
timisyourfriend
Nov 12, 2006 12:29 PM
STG3PWR
Feb 19, 2005 08:27 PM
CNSK
Aug 4, 2004 06:29 AM
