will really small chare piping work (if its the size of the turbos exit)?
Old Oct 29, 2003 | 06:34 PM
jetpilot's Avatar
Default will really small chare piping work (if its the size of the turbos exit)?
I am doing a sohc homemade setup (who isnt?) and I have a oyoa turbo and a dsm sidemount intercooler, the exit on the urbo and the entry on the intercooler are very small and I can have aluminum piping made in this diameterr for very very cheap. Will it have any negative downsides? its only like 1.5inches diameter but I thought hat if the turbos exi is the same size it wouldnt help to be any bigger (just like crush bent exhausts dont help much)
Old Oct 29, 2003 | 06:44 PM
sporkcrx's Avatar
Default Re: will really small chare piping work (if its the size of the turbos exit)? (jetpilot)
I'm curious too.
Old Oct 29, 2003 | 06:46 PM
TorganFM's Avatar
homemadeturbo: why not to use aluminum
Old Oct 29, 2003 | 06:52 PM
bretx0r's Avatar
Default Re: will really small chare piping work (TorganFM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TorganFM &raquo;</TD></TR><TR><TD CLASS="quote">homemadeturbo: why not to use aluminum
thats not charge piping though
Old Oct 29, 2003 | 06:59 PM
Bailhatch's Avatar
makes no sense
Old Oct 29, 2003 | 07:05 PM
MADEINIRAQ's Avatar
Default Re: will really small chare piping work (Bailhatch)
aluminum is fine..
the diameter wouldn't matter too much aslong as you don't step down in size.. and if you do.. not too much.
Old Oct 29, 2003 | 07:41 PM
Johnyquest's Avatar
Default Re: will really small chare piping work (madeiniraq)
yeah, try to stay at about 2", because the air does expand after it passes through your intercooler. Anything bigger than 2" is overkill at low boost, and anything bigger than your TB is overkill at ANY boost level.
Old Oct 29, 2003 | 07:49 PM
lazerus's Avatar
Default Re: will really small chare piping work (Johnyquest)
DSM sidemount pipe size should work fine for what you're asking of it..
paul93sir
Sep 18, 2004 06:39 AM
ghettochild
Aug 10, 2004 07:02 PM
Soon_2b_evil
Aug 20, 2003 08:33 AM
