would a faulty m/c cause uneven brake pad wear?
Old Oct 29, 2003 | 10:33 AM
slut's Avatar
Default would a faulty m/c cause uneven brake pad wear?
My right front and left rear calipers aren't bitting as hard as the others. Take into mind that the brake lines are criss-crossed from the prop valve(which is normal).Could this uneven brake pad wear be from a faulty m/c or from frozen calipers. Setup: gsr brakes all around on a 97 hatch with new brake pads.
Old Oct 29, 2003 | 10:41 AM
Ricey McRicerton's Avatar
Default Re: would a faulty m/c cause uneven brake pad wear? (****)
I would bet that a fauly MC would give you more of an air in the brakes feel. Possibly a bad prop valve though.
Old Oct 29, 2003 | 11:52 AM
DX Hybridizer's Avatar
Default Re: would a faulty m/c cause uneven brake pad wear? (Ricey McRicerton)
Or one further a dying caliper as well.
If not that I'd move up the line to the prop valve for sure
After that then check the m/c. But odds are the m/c would cause a weak/mushy pedal feel, almost like no pressure.
Old Oct 29, 2003 | 12:57 PM
DumpedSi's Avatar
Default Re: would a faulty m/c cause uneven brake pad wear? (DX Hybridizer)
I have a MC and porpotioning valve from a 2000 si if you do decide to replace it
johnwohl
Jun 27, 2010 08:52 PM
K24_Y61P
Suspension & Brakes
12
Nov 9, 2008 05:21 PM
jeffk182
Apr 26, 2005 06:36 PM
S.Celia
Jan 6, 2004 02:56 AM
