What is this sensor?
Old Oct 29, 2003 | 09:45 AM
ef-sihatch's Avatar
Default What is this sensor?
Wanted to know exactly what this is, how it works, and how you can tell if its defective.
Old Oct 29, 2003 | 09:58 AM
-16V-'s Avatar
Default Re: What is this sensor? (ef-sihatch)
i was woundering the same thing i broke on my z6 intake manifold.
Old Oct 29, 2003 | 10:04 AM
Vinceg99's Avatar
Its the purge solenoid.
It has to do with your emissions, sorry dont know how to test it though??
Old Oct 30, 2003 | 05:58 PM
JenniferDC5's Avatar
i don't think it will cause a problem if it was broken. it's mainly for smog check they made me put one on when I smoged my B16a
Old Oct 30, 2003 | 06:10 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Gasoline releases vapors. Automakers are not allowed to just release those vapors into the atmosphere. So you have a charcoal canister that absorbs Gas vapors while the engine is off. When you turn on the engine, the ECU uses that little valve you have in your hands to send vacuum to the charcoal canister. Vacuum at the canister opens a valve that lets the accumulated gas vapors go to the throttle body where they are burnt.
That is part of the EVAP system in your car. That's why you have three hoses connected at the canister. One is for the gases from the tank, the other is for the gases to go to the throtle body and the other opens the valve that lets the vapors out. I don't know how to test it, although you could check for vacuum at the valve.
Pretty simple.
gabrielsousa
11
Jan 18, 2015 03:35 PM
maziospzza
25
Apr 15, 2010 06:58 AM
classicalgq
17
Aug 4, 2008 08:13 AM
NathanMorris
Aug 2, 2007 07:52 AM
Ray
Jan 11, 2002 06:25 PM
