d16z6 ?
Old Oct 29, 2003 | 04:47 AM
fast-rex's Avatar
Default d16z6 ?
I am doing a mini me swap and I want to know if I shold do some thing to the block while the head is off to give me some more HP ? the - eng - will be turbo THANX GUY'S
Old Oct 29, 2003 | 09:40 AM
LoSt is BlaCk's Avatar
Default Re: d16z6 ? (fast-rex)
is the motor still in the car, if so there is not much!
Old Oct 29, 2003 | 01:24 PM
EFb18b's Avatar
Default Re: d16z6 ? (Chpt1onBOOST)
yeah, If ya have the head off you might as well take the whole damn thing out and give it a slight over bore and get some lower compression pistons and stronger rods so you can up the boost a little. Don't forget about rebalancing the crankshaft, replacing the oil pump, get stronger rod bolts, and replacing all the bearings. Are ya broke yet?
Old Nov 4, 2003 | 04:50 AM
fast-rex's Avatar
Default Re: d16z6 ? (Redlineracer)
well thanx bro! I just have the cash to biled the head for now so I am not doing the block.
Old Nov 4, 2003 | 12:42 PM
EFb18b's Avatar
Well if you aren't gonna do anything to inside the block, you could take it to a machine shop and have them see if the top should be milled level, replace the headgasket, of course, and see if hondata has an intake manifold gasket for that head and I would at least try to replace the head bolts or main studs with arp bolts and studs.
tensecpass
28
Dec 28, 2007 11:56 AM
junior_tm
Jul 30, 2007 07:54 PM
Supratt85
Jul 29, 2006 08:59 PM
lilcasino
Apr 24, 2002 05:30 PM
