e-cutout question... NEED HELP
in the instructions to install an e-cutout, it says to wire the positive to a switched fuse which is only on when the ignition is on. why is this. would i be able to wire it to just the battery terminal? what would be the downside to this. need help quick. thanks alot
The switched fuse side is so the cutout only works when the key is on. Battery terminal it will have 12v+ all the time, what if the wire burns in two= dead short= your car is on fire. Now if you install a fuse less than 12 inches from the battery, no fire.
EFinawesomeman
Dec 31, 2012 09:34 AM
ppfalcon
Dec 11, 2005 01:14 PM
4doorH22
Nov 27, 2001 09:48 AM
