d16a6 swap into cx help!!!!
Old Oct 28, 2003 | 05:53 PM
89dohcEF's Avatar
Default d16a6 swap into cx help!!!!
what things would i need from the d16a6 to put into my 92 cx, like motor mounts, shift linkage, etc. lemme know thanks
Old Oct 28, 2003 | 06:01 PM
billyhoe's Avatar
Default Re: d16a6 swap into cx help!!!! (zc_civic91)
im guessin the basic stuff, mounts, linkage, axles, and add a couple wires to your ecu. im namin stuff off the top my head so forgive me if i left anything out
Old Oct 28, 2003 | 06:29 PM
degooser's Avatar
why would you want to put a d16a6 in your car? get a z6 and get that vtec power....
your basically putting a DX motor in your car...also the a6 is an older motor....
Old Oct 28, 2003 | 07:58 PM
DumpedSi's Avatar
Default Re: d16a6 swap into cx help!!!! (degooser)
Stock a6 will hang with z6..
I think it should be really simple, it will drop right in but you wont be able to use the tranny off the new motor due to fact of it being cable and your car is hydro.. just use you old tranny and shift linkage and your set.. Im not sure if you need to do any wiring
ChrisHdz94
Jul 31, 2013 08:05 AM
95cxcivic
Oct 17, 2012 04:57 PM
noboostedEGo
Oct 20, 2005 12:39 PM
wantboost
Apr 7, 2005 08:06 PM
0ptimus prime
May 12, 2004 01:56 PM
