quick quesion on 97 coupe ex
Old Oct 28, 2003 | 04:21 PM
phreakmang's Avatar
Default quick quesion on 97 coupe ex
Does it have ABS?
Looking at doing rear disk conversion, seeing if i'll run into any problems along those lines.
Old Oct 28, 2003 | 04:42 PM
civic-4-ges's Avatar
Default Re: quick quesion on 97 coupe ex (phreakmang)
I thought EX coupes had rear discs?
Old Oct 28, 2003 | 04:43 PM
blackhatchy's Avatar
yes, it does have ABS.
phreakmang's Avatar
Default Re: quick quesion on 97 coupe ex (civic-4-ges)
SI's do, EX's have drum brakes.
Old Oct 28, 2003 | 04:49 PM
phreakmang's Avatar
"DC2 rear disc brakes. Everything that you need to convert drums to discs on a 92-00 civic. Ebrake lines and regular brake lines included."
gonna pick this up, was informed that if you don't have disks to begin with that ABS does not effect it.
Old Oct 28, 2003 | 05:16 PM
EL Vap133's Avatar
Yeah, any rear disk set up will do, no problems...
Old Oct 28, 2003 | 05:19 PM
The Internet Tough Guy's Avatar
Default Re: quick quesion on 97 coupe ex (EL Vap133)
my 96 ex has rear drums and NO abs.
Old Oct 28, 2003 | 06:05 PM
RyanEJ8's Avatar
Default Re: quick quesion on 97 coupe ex (blackhatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy &raquo;</TD></TR><TR><TD CLASS="quote">yes, it does have ABS.</TD></TR></TABLE>
Not all EX coupes have ABS, just the automatic ones.
Old Oct 28, 2003 | 06:06 PM
Default Re: quick quesion on 97 coupe ex (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Not all EX coupes have ABS, just the automatic ones.</TD></TR></TABLE>
oh shiz, my bad
Old Oct 28, 2003 | 06:13 PM
2slow2curious's Avatar
trust me no ABS cuz early on my drive home from work it was raining a bit and i went to slow down on a yellow light and it started to slip and slide and I almost crashed into a pimped out eclipse GST .. he wuda been pissed
Old Oct 28, 2003 | 06:16 PM
hybridcivicex's Avatar
Canadian Ex's have rear disc brakes and ABS, my friend has it on his. look for the #2 as the first number in the VIN code. 2 represents candadian model.
Old Oct 28, 2003 | 06:24 PM
Ricey McRicerton's Avatar
Default Re: (hybridcivicex)
ABS was an option with the 4 wheel disk brakes. If you are converting to disk brakes, then no you don't have it. One easy way to check is to go out and slam on the brakes. If they lock up, then nope.
shortlid
Mar 22, 2007 06:35 AM
2DoorBandit
Jan 5, 2007 06:11 PM
Hatchless96
May 28, 2006 10:31 AM
GapxGuy
10
May 27, 2006 06:18 PM
SpoonFedHatch
Dec 10, 2003 09:48 AM
