sohc sleeved vs any swap
Old Oct 28, 2003 | 03:09 PM
Honda-Hooligan's Avatar
Default sohc sleeved vs any swap
i currently have a sohc turbo honda but im trying to decide if i wanna do a swap (b16 crvtec or h22) or if i just should stay sohc and sleeve the block with forged internals so i can run high boost
if swap is the answer then what should i drop in ( i been thinking h22 but i do not know how convinient this is)
if some1 can tell me how to post pic here i will really apriciate
Old Oct 28, 2003 | 06:45 PM
djickabod's Avatar
Default Re: sohc sleeved vs any swap (zigzag765213)
When posting pic you do this...
1) you want to copy the address in properties
2) put this before the address
then you pix should post.
Modified by djickabod at 4:18 AM 10/30/2003
Old Oct 29, 2003 | 05:40 PM
Kendall's Avatar
The question you have to ask yourself comes down to a few basic engine principles. How much air do you plan on moving, how much boost, how high do you want to rev, how much torque do you want, etc. Also consider that in order to run "high boost" you will also probably want more airflow up top, so that means head work and valve train modification. It's perfectly possible to build a powerful boost fed SOHC, but big power numbers come much easier with B-series engines.
tunertuning
Jan 12, 2006 03:15 PM
SiRAaron
Apr 6, 2005 10:20 AM
944drifter
Mar 16, 2005 05:16 PM
munster
Feb 26, 2004 06:47 PM
mantic6t9
Sep 15, 2002 10:31 PM
