b16 backfiring crazy
Old Oct 28, 2003 | 01:40 PM
doublejz's Avatar
Default b16 backfiring crazy
Ok, i put a b16 2nd gen in a 93 eg. Just realized that I had the firing order incorrect fixed it and got all my power back. Only thing is that it is backfiring now. Around 4k rpms its ridiculous, sounds like a machine gun. I did notice that the intake and exhaust cams aren't straight across anymore Theres like 1-2 teeth difference between the cam gears being straight across. Could that be doing it? I'm running outta ideas, and suggestions would be greatly appreciated.
Old Oct 28, 2003 | 01:55 PM
mmuller's Avatar
Mad Scientist
Default Re: b16 backfiring crazy (doublejz)
yeah, cam timming could make your car backfire, also check ign. timming
Old Oct 28, 2003 | 04:13 PM
doublejz's Avatar
Default Re: b16 backfiring crazy (mmuller)
ok well the timing is perfect now, and its still back firing
Old Oct 28, 2003 | 04:16 PM
mmuller's Avatar
Mad Scientist
well since cam timming and ign. timming is ok, then you could check your ecu, what ecu are you running?
have a cat?
Old Oct 29, 2003 | 04:00 AM
doublejz's Avatar
im running a p30. and my cat is hollow
Old Oct 29, 2003 | 07:13 AM
sleepyEK's Avatar
if your cat is hollow and you are running rich then you will definitely be backfiring.
Old Oct 29, 2003 | 09:04 AM
notstock93's Avatar
Default Re: b16 backfiring crazy (sleepyEK)
If your cat is hollow and you have a OBD-II, you car will run like ****. Unless its OBD-I or 0, you need to disable the secondary 02 sensor...this of course is assuming you're OBD-II.
Old Oct 29, 2003 | 11:18 AM
doublejz's Avatar
im running obd 1, im just wonderin if bent valves would be doing this. I kinda had the timing off like 7 teeth before and im not sure if the valves are bent or not. i know i know do a compression/leakdown test. I just haven't gotten to it, or have the gauge and ****.
Old Oct 29, 2003 | 02:46 PM
notstock93's Avatar
Default Re: (doublejz)
bent valves wouldnt cause a backfire, they would cause aweful idle and bogging, loss of power. But if it happens only at a certain RPM, and its not VTEC related, then start replacing things on your ignition system. Cap and rotor, hopefully its not the dist. I doubt it is. Change the Ignition coil too.....
Old Oct 29, 2003 | 03:18 PM
doublejz's Avatar
Default Re: (notstock93)
well heres the thing that really gets me. for the firing order i know its 1342 going clockwise. But on my old d16z6 i tried that and it didn't work but when i had it 1243 it ran fine. on my current b16 if i have them as 1342 it backfires crazy, if i switch them to 1243 which i had it, it boggs at all rpms, and has no power. I drove 100 miles this way, just no power, no misses, w/ occasional back fires, and its a gas hog and can smell raw gas. So i dunno whats going on. I changed cap and rotor, didn't help any.
Modified by doublejz at 7:55 PM 10/29/2003
Modified by doublejz at 7:56 PM 10/29/2003
Old Oct 29, 2003 | 03:57 PM
doublejz's Avatar
debating if it is worth taking the head off and looking at the valves, and spending $75 to replace head gasket
Old Oct 29, 2003 | 09:11 PM
notstock93's Avatar
the firing order is indeed 1342....so change it back. Re-check your cam gears to make sure they are at zero, check all your vacuum lines to your intake mani. and go over your ignition system about three times to make sure you didnt over look anything. I really think this is an ignition problem. check your wires for impedence and do a compression check. That should tell you alot.
Old Oct 30, 2003 | 04:51 AM
doublejz's Avatar
Well I'm just a genius and a retard. I figured out my problem. I was running vp racing fuel 110 octane gas, which i looked at there webpage last night and found out, yea it was leaded gas. So I drained it and put some 94 octane in and boom, shes running fine now
drumminforev
Nov 30, 2006 09:31 AM
egvtec
Aug 14, 2005 01:48 PM
sporkcrx
Oct 6, 2003 09:15 PM
Phatwhippin_CRX
Oct 24, 2001 06:14 PM
