b18b in Eg MAP senser Q??
Old Oct 28, 2003 | 10:49 AM
White Smoke's Avatar
i my honda
Global Mod
Default b18b in Eg MAP senser Q??
I have already searched!
Ok..I put an 98 b18b in my boys eg with an p75 obd1 ls ecu and his stock map senser is on the firewall and is wired straight into the main harness. The ls motor has the senser on the TB and is wired into the engine harness witch is pluged into the main harness. Am I suposted to splice the new TB MAP senser into the extra clip that comes off the MAIN harness(witch wires?) or am I suposted to leave it hooked up to the engine harness that came with th b18b and not hook up the old map harness?
Thanks So Much Guys
Old Oct 28, 2003 | 11:23 AM
i my honda
Global Mod
Default Re: b18b in Eg MAP senser Q?? (si2die4)
Come one guys can someone PLEASE help me out
Old Oct 28, 2003 | 10:36 PM
i my honda
Global Mod
Some one has GOT to know this!
Old Oct 28, 2003 | 11:01 PM
ace1875's Avatar
The 3rd wire on the MAP sensor wire on a DX is Yellow/green.
the third wire on the throttle type is Yellow/Red
your best bet is to just get a LS harness
Old Oct 28, 2003 | 11:09 PM
salbaje's Avatar
unplug the one on firewall and put on plug on the tb. if you need Ls harness i got it
Old Oct 29, 2003 | 09:03 AM
i my honda
Global Mod
Default Re: b18b in Eg MAP senser Q?? (ace1875)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace1875 &raquo;</TD></TR><TR><TD CLASS="quote">
your best bet is to just get a LS harness</TD></TR></TABLE>
I am using an ls harness! I am using an ls engine harness which is plugged into the stock civic tower clips (main harness) witch goes to my p75.
I am still not sure if you understand me??? The ls engine harness has a clip on it for the map. You are saying NOT to use this and just let it hang correct?? There is also an map sensor plug right off of the civics MAIN harness witch you are telling me to use for my TB MAP right?? This makes sense since I am using an obd1 (p75) ecu so the pin outs would be the same as the civic.
Since the civics clip for the map is different, i change the plug to the ls one with the&gt;&gt;&gt;&gt;YELLOW/GREEN going to the RED/GREEN..
Is This correct???
Thanks Again
Old Oct 29, 2003 | 08:35 PM
i my honda
Global Mod
BoostedEgHatchFl
Feb 19, 2012 07:23 PM
95lscivic
Dec 28, 2009 06:41 PM
hammergunner
Feb 22, 2009 05:12 PM
MR.johnson
12
Apr 27, 2008 06:10 PM
