Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
valve adjustment on a 98 CRV...how?
Old Oct 27, 2003 | 06:24 PM
_Endless_'s Avatar
Default valve adjustment on a 98 CRV...how?
i have no problem doing a valve adjustment on my 2000 SiR but when i tried it on my parents 98 CRV, the rocker arm keeps on moving. please refer to the pic below
i rotated the crank to bring #1 to TDC and was about the to loosen the locknut when i noticed that the whole rocker arm labelled B in the pic moves even if the locknut hasn't been loosen yet.
i thought it was broken but someone told me that it's suppposed to move if it's a non-vtec head. if it were normal, how can i adjust the valves accurately? each time you try tightening the locknut or loosening it, it moves and i'm afraid that it might not be accurate so i didn't proceed.
is the part labelled B (in the pic) supposed to move without effort when you wiggle it with your fingers? if so, any technique on how to do valve adjustment on it to lessen the movement thus resulting in a more accurate adjustment?
any help will be appreciated.
Old Oct 28, 2003 | 03:14 AM
1bad-eg's Avatar
Default Re: valve adjustment on a 98 CRV...how? (_Endless_)
I haven't had much experience with the CRV, but if it's anything like the non-vtec integra motor, those locking nuts should not move.
Old Oct 28, 2003 | 06:56 PM
^jefs0ng's Avatar
Banned
WEll here's an easy question.. do you have a writeup on how to do a valve adjustment for your b16? I need to get that done..
Old Oct 29, 2003 | 05:50 PM
_Endless_'s Avatar
Default Re: (jefs0ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jefs0ng &raquo;</TD></TR><TR><TD CLASS="quote">WEll here's an easy question.. do you have a writeup on how to do a valve adjustment for your b16? I need to get that done..</TD></TR></TABLE>
try this http://www.c-speedracing.com/h...t.php it's for a b18c but it's also the same as B16.
NEDan
Honda Fit
Aug 4, 2017 06:30 AM
lazyxmofo
May 23, 2012 07:04 PM
Dc4LsTeG
Jan 12, 2012 03:21 PM
Rob Dizzle
21
Jul 3, 2003 12:33 AM
raene
Jun 27, 2001 10:45 PM
