12.8:1
i was wondering if 12.8:1 with hondata (ib super dupers) will be streetable on 91octane has anyone done it or do i have to start mixing gas well let me know im curious to here what people have and havent done with this kind of compression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy »</TD></TR><TR><TD CLASS="quote">Throw some octane booster in! Just to be safe...</TD></TR></TABLE>
Over the counter octane booster sucks. He'll go from 91.0 to 91.7 octane.
You could always run some Toulene in there. Now that's a real octane boost. I actually ran a gallon of Toulene mixed in a tank in my Civic. Didn't seem to notice anything.
http://www.elektro.com/~audi/audi/toluene.html
*Views held or expressed in above article are in no way supported by TodaSi nor does TodaSi bear any responsibility for said article.
i'm runnin exactly 12:8:1 right now on 91 octane tuned on a vafc....timing is at 12 or 13...can't remember exactly which...wouldn't recommend goin any higher than this and just to be safe tune it on hondata to get all the kinks out....good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus »</TD></TR><TR><TD CLASS="quote">you will have to retard the timing to run 91 octaine</TD></TR></TABLE>
Ignition timing is what you are talking about right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omega11855 »</TD></TR><TR><TD CLASS="quote">will advancing the intake and retarding the exhaust help to bleed of some compression(dynamic)</TD></TR></TABLE>
Dynamic CR = (cylinder volume at the point intake valve closed shut) divided by (cylinder volume at TDC). So I think retarding your intake cam will lower the compression, exhaust cam probably has nothing to do with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omega11855 »</TD></TR><TR><TD CLASS="quote">i was wondering if 12.8:1 with hondata (ib super dupers) will be streetable on 91octane has anyone done it or do i have to start mixing gas well let me know im curious to here what people have and havent done with this kind of compression</TD></TR></TABLE>
Well even with all the tuning done to your car running on just 91 octane a romping it to say 9k is not good on 91 but to be safe just mix it! never go above 6k on just 91 because after that you will just start detonanting the motor because of the extreme heat caused by the this compression.
If you want your motor to last and dont' look at a rebuild within the next year then just mix it and be safe. I have seen to many motors well even after tuning fail due to high rpm and detonation causing rods to sieze to the crank.
you will make good hp with this compression but mix some 110 once in agreat while just for added insurance
Yes , but you will have to take timing out of your high to medium load timing maps . I am running 12.5 with no problems but a motor with 11.1 and full timing running pump gas would make more power than a high compression motor with retarded timing for pump gas . Rule of thumb is build your engines compression so full timing can be run for the gas available .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omega11855 »</TD></TR><TR><TD CLASS="quote">where is there 94 in so- cali?</TD></TR></TABLE>
****, my bad,,, sucks to be you
Options
May 29, 2007 11:36 AM
Tofurky
Aug 26, 2003 11:49 PM
