will a cracked exhaut manifold cause my check engine light to come on?
I had a dc headder on my stok sohc vx engine, the original manifold was cracked rite down th middle, once i put the stock cracked manid on my engine the check engine light came on would it be from the cracked manifold or should i look for something elese that may e causing he light to come on?
Might cause one, due to sample dilution. You may be sucking air in the manifold, and freaking your O2 out, causing a code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolveu2 »</TD></TR><TR><TD CLASS="quote">Might cause one, due to sample dilution. You may be sucking air in the manifold, and freaking your O2 out, causing a code. </TD></TR></TABLE>
the same way an exhaust leak will cause your car to fail inspection for too high oxygen content. to answer, yes it may cause a code.
spooncivic28
10
Mar 18, 2006 05:48 PM
