Question for all my people using hondata....
Old Oct 27, 2003 | 03:52 PM
NOTENOUGHBOOST's Avatar
Default Question for all my people using hondata....
...every now and then when I start my car, the car idles real low and I have to give it some gas in order for it to stay running. (the kind of rough idle you get when your IAC is going out) If I let it run for a few minutes, it stops. I have a P72 w/boost program.
Wanted to know if anyone else with odb2 to 1 conversion had same problem.
Old Oct 27, 2003 | 04:20 PM
Default Re: Question for all my people using hondata.... (littlechoppab20)
No one has experineced this problem?
Old Oct 27, 2003 | 08:14 PM
JDMCivicEF9's Avatar
My guess is double check your wiring, since you have a OBD2-OBD1 conversion harness. Your problem might be in that area. My other guess could be the boost program on the P72 ECU. Other than that, just hope its a simple problem.
Old Oct 27, 2003 | 08:25 PM
boostedsol's Avatar
I have a hondata s200 w/ boost on my 94 del sol VTEC, which uses a p30 ecu. I am originally OBD 1 so I never had to convert to anything, but I am currently running a basemap, and do not have any issues you are talking about. Have you gotten it tuned yet, or are you running a basemap?
Old Oct 28, 2003 | 09:44 AM
Default Re: (boostedsol)
Yeah it has been tuned, and I have trie changing from a conversion harness bought of ebay to a Skunk2 harness and have the same problem.... I guess I'll just need to get another ecu and have it socketed.
Old Oct 28, 2003 | 09:48 AM
HXMan's Avatar
I have had the same problems a couple times with a stock obd1 p72 and conversion harness.
I wouldn't worry about it unless it is happening all the time.
BTW...are you running a GSR head and manifold? If not just get a p28 its alot cheaper then an OBD1 p72.
Old Oct 28, 2003 | 12:02 PM
Default Re: Question for all my people using hondata.... (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">I have had the same problems a couple times with a stock obd1 p72 and conversion harness.
No it not all the time, I just don't want it to get any worse!!!!! I have the b16 head and a type r manifold.... The only reason why I got the P72 was for the knock sensor.
Old Oct 28, 2003 | 12:09 PM
PHiZ's Avatar
I've had that problem with a lot of aftermarket ecu chips/programs, I consider it normal. You might be able to fix it by tweaking the idle columns in your rom.
-PHiZ
Old Oct 28, 2003 | 12:47 PM
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">I've had that problem with a lot of aftermarket ecu chips/programs, I consider it normal. You might be able to fix it by tweaking the idle columns in your rom.
-PHiZ</TD></TR></TABLE>
To be honest with you.. I don't know if you can do that with hondata... I'll look in to that!
Old Oct 28, 2003 | 02:02 PM
madman604's Avatar
ill bet your car runs like a champ when you first start it up but after its warm and you start up again it idles crappy.
Old Oct 28, 2003 | 02:09 PM
b16 matt's Avatar
Default Re: (Turbo E)
mine does the same <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">ill bet your car runs like a champ when you first start it up but after its warm and you start up again it idles crappy.</TD></TR></TABLE>
Old Oct 28, 2003 | 03:36 PM
The funny thing is that it goes away once it "warms up" good, or runs for a while. With the new tubular manifold by rev hard... I've noticed that my performace after the car heats up, doesn't decrease as much as it used to
Old Oct 28, 2003 | 03:54 PM
madman604's Avatar
Default Re: (littlechoppab20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlechoppab20 &raquo;</TD></TR><TR><TD CLASS="quote">
The funny thing is that it goes away once it "warms up" good, or runs for a while. With the new tubular manifold by rev hard... I've noticed that my performace after the car heats up, doesn't decrease as much as it used to</TD></TR></TABLE>
yup. known hondata (tuning) problem. not sure why it is as no one seems to have an answer. mine used to do it all the time, then retuned and only happens 1ce in a long while
Old Oct 28, 2003 | 04:22 PM
I've gotten more help from honda-tech, then I could get from the hondata message board!!!!!!
Old Oct 28, 2003 | 06:32 PM
HXMan's Avatar
Yep. The only 2 times it has happend to me was after work when I went to a gas station and filled up.
The trip is just long enough to get the car warmed up, but not that great. Then when I turned it on after gassing up it idled so low it would kill.
I don't have hondata yet BTW.
Old Oct 28, 2003 | 06:36 PM
PHiZ's Avatar
Default Re: (HXMan)
Hrm, I mostly see the problem on cold starts. And it goes away on warmup/driving.
-PHiZ
Old Oct 28, 2003 | 09:23 PM
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Hrm, I mostly see the problem on cold starts. And it goes away on warmup/driving.
The exact symptoms of what I'm getting... If it is so common then, maybe it's not the ecu, it's the damn tuner's fault. Don't get me wrong, my car runs great, but when something is not perfect, I tend to start acting ****!!!!!
Old Oct 28, 2003 | 09:42 PM
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j. davis &raquo;</TD></TR><TR><TD CLASS="quote">The regular MAP tune doesn't have idle perfect, but
mostly there. You need to take more fuel out of the part throttle
maps; I tuned 0-1500 rpm in the 25 and 24 in/hg columns, but idle
properties are affected all the way to ~ 16in/hg of vacuum.
Excerpted from an email, but just to shed some light on the subject.
I say just live with it, and let the car warm up. Problem with troubleshooting it, is that you basically would have to let the car fully cool down inbetween tunes, and it'll take a lot of the tuner's time...
-PHiZ
PTVDesign
Engine Management and Tuning
Apr 9, 2018 01:53 AM
projectwidow
Mar 15, 2008 11:21 PM
acman1
Jan 29, 2008 07:50 PM
flight50
Nov 27, 2005 09:57 AM
JDEM1
Feb 1, 2005 11:30 AM
