NEED WIRING DIAGRAM
Old Oct 27, 2003 | 01:18 PM
horsedangler's Avatar
Default NEED WIRING DIAGRAM
does any one have a wiring diagram for a b16 sir-2
Old Oct 27, 2003 | 01:24 PM
B.'s Avatar
B.
400 HP Club
Default Re: NEED WIRING DIAGRAM (horsedangler)
http://www.hasport.com may have something if it relates to ecu's and what not. What do you need to know?
Old Oct 27, 2003 | 01:32 PM
Default Re: NEED WIRING DIAGRAM (THE B)
I have a 95 ex and I put a sir2 in it and the is a extra plug hanging under the manifold. i'm wanting to make sure all connectors are plugged in the right location
since some of the connectors are the same.
Old Oct 27, 2003 | 01:36 PM
BauleyCivic's Avatar
Risky Business
http://www.hybridgarage.com/tech/index.html
Old Oct 27, 2003 | 01:48 PM
B.'s Avatar
B.
400 HP Club
it might be the crank case angel sensor or knock, if so your ecu (p28) its not looking for them and dont need to be plugged in...
Old Oct 27, 2003 | 01:51 PM
knock is wired up and I am running a p30 ecu, it does have a cel but I havent run codes. if the vss is not hooked up will it prevent v-tec from engaging?
Old Oct 27, 2003 | 01:53 PM
TurboBumblBee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by horsedangler &raquo;</TD></TR><TR><TD CLASS="quote">knock is wired up and I am running a p30 ecu, it does have a cel but I havent run codes. if the vss is not hooked up will it prevent v-tec from engaging?</TD></TR></TABLE>
yes cause you have to be moving for vtec to work and w/ out that hooked up the car will think that your not moving cause its not getting a signal
gnccracer20
Mar 23, 2009 03:23 AM
3a_eg_hatch
Mar 16, 2008 07:35 PM
