NEED WIRING DIAGRAM
400 HP Club
Re: NEED WIRING DIAGRAM (horsedangler)
http://www.hasport.com may have something if it relates to ecu's and what not. What do you need to know?
Re: NEED WIRING DIAGRAM (THE B)
I have a 95 ex and I put a sir2 in it and the is a extra plug hanging under the manifold. i'm wanting to make sure all connectors are plugged in the right location
since some of the connectors are the same.
400 HP Club
it might be the crank case angel sensor or knock, if so your ecu (p28) its not looking for them and dont need to be plugged in...
knock is wired up and I am running a p30 ecu, it does have a cel but I havent run codes. if the vss is not hooked up will it prevent v-tec from engaging?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by horsedangler »</TD></TR><TR><TD CLASS="quote">knock is wired up and I am running a p30 ecu, it does have a cel but I havent run codes. if the vss is not hooked up will it prevent v-tec from engaging?</TD></TR></TABLE>
yes cause you have to be moving for vtec to work and w/ out that hooked up the car will think that your not moving cause its not getting a signal
