Need help for rear camber~
Old Oct 27, 2003 | 01:09 PM
3R1C's Avatar
Default Need help for rear camber~
I have a 2000 civic si...i got my car lowered and the camber is too much now. wat can i do? how does camber kit help? is that easy that i can install the kit myself? just give me some opinions...thanks.
Old Oct 27, 2003 | 01:44 PM
b20turbojason's Avatar
Default Re: Need help for rear camber~ (3R1C)
the companys that offer camber kits are designed only to correct the camber of the alignment process of your car.so you need to get a camber kit and have it installed by someone that can also do an alignment. there are a few companys that offer kits. sprint , ingall's, progress and a few others, all differ in price and camber adjustment.do your stuying. look around get details and prices
Old Oct 27, 2003 | 01:49 PM
if you are only haveing rear problems you can get some washers from home depot and put them between the rear upper control arm and the body of the car and that will correct the rear.but you will still need an alignment cause it knocks of the toe adjustment in the rear.
Old Oct 27, 2003 | 04:21 PM
pro1342's Avatar
I agree......camber kits or washers/shims and an alignment.
JDKX
Suspension & Brakes
Mar 21, 2016 01:50 PM
lif3tak3n
Feb 7, 2007 12:38 PM
es_squared
Apr 3, 2004 02:04 AM
bartek_b
Oct 7, 2003 04:45 PM
