Idle problem- swapped obd1 d15 in a crx
Old Oct 27, 2003 | 10:47 AM
boosh's Avatar
Default Idle problem- swapped obd1 d15 in a crx
alright, i have a 95 civic dx motor in my 88 HF. i'm running the obd0 alternator, distributer, injectors and ecu. my intake air temp sensor was not plugged in and when i cranked my car up it jumped to about 3500 rpns and then after about 10 seconds it dropped to a surging idle of 1000-2000 rpms. i plugged the IAT sensor in and now when i crank my car up, it immediatley jumps to 4000 rpms and doesnt drop back down. i dont want to convert to obd1 because thats money that i dont have. could it be that my 8 valve ecu cant make my newer 16 valve motor idle correctly? or something else?
TIA
Old Oct 27, 2003 | 11:45 AM
boosh's Avatar
Default Re: Idle problem- swapped obd1 d15 in a crx (boosh)
now its throwing code 12- exhaust gas recircualtion lift sensor. please help, this is my daily driver and i cant effectively drive it...
Old Oct 27, 2003 | 05:11 PM
boosh's Avatar
bump please help... anyone
Old Oct 27, 2003 | 05:23 PM
JonGP4's Avatar
yeah i'm pretty sure you can't run your HF ECU, on the 16 valve motor.. also your HF motor had a EGR valve, the motor you have now doesn't have one so your always gonna be throwing that code.. first things first.. get a 88-91 si ecu, or a OBD0 integra ecu w/o VTEC.. thats your best option
Old Oct 28, 2003 | 10:52 AM
boosh's Avatar
Default Re: Idle problem- swapped obd1 d15 in a crx (JonGP4)
but are you sure that will fix my idle problem? because i'm a poor guy, if i dont have to spend money i dont want to you know?
Old Oct 28, 2003 | 03:26 PM
scdarksol's Avatar
dude bid on a SI ecu on Ebay it's cheap.
tallkan
Engine Management and Tuning
12
Jun 7, 2009 11:48 AM
k_lude
Aug 23, 2006 01:10 AM
N1 Andy
Mar 8, 2006 12:12 PM
Petah
Apr 16, 2003 03:04 PM
