since VAFC install - Car is much slower, and slow to climb through the RPMS
Old Oct 27, 2003 | 07:15 AM
2camsaam's Avatar
Default since VAFC install - Car is much slower, and slow to climb through the RPMS
Just installed a VAFC, now my car is running slower than it should and I don't hear vtec engage any more. My air/fuel numbers look the same I have a 95 civic w/ a JDM B162nd gen motor.
When first driving it last night, I noticed that VTEC was weak and also that it kicked in to damn early. I found that it was set to kick in at 4800 RPMs. I changed it to 5800 RPMs, it worked fine after that, in fact it seems a bit more powerful than usual.
This morning, however, VTEC never engages and all my setting appear to be as they were yesterday, but I will look again.
Is there anyway to have the VAFC connected but have it leave all the stock setting alone?
I have no Check engine lights, and have driven about 80 miles so far.
Old Oct 27, 2003 | 02:02 PM
2camsaam's Avatar
Default Re: since VAFC install - Car is much slower, and slow to climb through the RPMS (2camsaam)
help someone...
Old Oct 27, 2003 | 02:35 PM
Hybridize's Avatar
Well there's really not that much to say... If all of the fuel settings are set to zero, and your vtec cross-over is about the same, the vafc should have no effect on your car.
The only thing I can think of that might be causing you the problems is that you or someone else did a hack job on the wiring(poor connections), the vtec pressure sensor is bad, or you car is low on oil...
2camsaam
Oct 27, 2003 02:03 PM
GreenGSR311
Sep 5, 2003 10:25 AM
EleanoR
Apr 17, 2002 10:29 AM
EleanoR
Apr 17, 2002 07:01 AM
