Need help confirming type of main bearings to order
Old Oct 27, 2003 | 06:41 AM
civic-4-ges's Avatar
Default Need help confirming type of main bearings to order
am starting to put my Y7 block back together and I am not sure about the bearings I need to order. Here are the letters I am grabbing from the block:
A-A-B-D-B
And the numbers from the crank:
3-2-2-2-3
Accoring to my Helms, if I am reading it correctly, I need the following in the same order
Yellow-Pink-Yellow-Brown-Green
I am coming up with these numbers accoring to page 7-8 of the Helms. Can anyone verify if my deductions are correct here?
This is the chart I am using to determine these:
Old Oct 27, 2003 | 09:44 AM
BatuKing's Avatar
Default Re: Need help confirming type of main bearings to order (civic-4-ges)
Yes your correct.. you can call the honda parts dept and they will also confirm with you..
FearDisH22a4
Dec 12, 2009 06:11 PM
Midori Green
Apr 6, 2008 09:37 PM
SkRiBLaH
Jul 28, 2004 10:24 AM
pip9
10
Jun 26, 2004 02:08 AM
