Rebuilding Tranny????
Old Oct 26, 2003 | 06:03 PM
dan89crxsi's Avatar
Default Rebuilding Tranny????
Hey I was wondering what is involved with rebuilding a tranny.....I am going to be rebuilding a engine I am getting with a tranny but I have no experience with rebuilding a trans and was wondering how it is done?
Old Oct 26, 2003 | 06:20 PM
omega11855's Avatar
by taking it with a bunch of cash to a pro
Old Oct 27, 2003 | 09:09 AM
dan89crxsi's Avatar
Default Re: (omega11855)
well yeah that would work except for people with out the bunch of cash so my original question remains unanswered
Old Oct 27, 2003 | 09:17 AM
omega11855's Avatar
well i did it with no knowledge so here it goes its still exspensive pprob more then a jused tranny but here we go you need to take tranny of motor unbolt all bolts around the tranny then the ones oon the side with springs and ball bearings then there is a hex bolt up top take that out now you should be able to crack the case crack the two halfes then get a something to strecth the clip up top with then ccompletly remove the upperhousing find a way to lock the gears take the 32mm sockert of the countershaft
now remove everything piece by piece keep it in order and replace whats worn some bearings washers synchros sleeves etc whatever it needs but remember these parts cost more then a used tranny and if your hard on trannys making new will only make it last a little longer lol ok thats about it anything else?
Old Oct 27, 2003 | 09:57 AM
BauleyCivic's Avatar
Risky Business
Step #1...get a helms manual...there is no way you're gonna get anything done without the helms. Read over what you need to do over and over again until you know what to do. I had to open my tranny up to replace a bearing, thats all I had to do. What all are you planning to do? Replace bearings and synchros? Make sure you get a helms. Mista Bone rebuilds trannys as a hobby, he knows everything...you should talk to him.
My tranny writeup: https://honda-tech.com/zerothread?id=596873
xxmastermindxx
Nov 14, 2006 11:07 AM
Lmgrcivic
Oct 10, 2005 07:43 AM
EFin' Kyle
Jun 14, 2005 08:05 AM
EK FLY
Feb 18, 2005 03:29 PM
0ptimus prime
Jun 27, 2004 12:12 PM
