I have a problem with my Clutch! Help
Old Oct 26, 2003 | 05:33 PM
JdmFront619's Avatar
Default I have a problem with my Clutch! Help
My clutch rattles when I release my foot off the clutch, but when I step and hold down on the clutch it stays quite. Anyone had this problem before? I just changed my clutch today and still having the same problem. Any tips or know a way to shut this ******* thing up? Thanks
Old Oct 26, 2003 | 05:42 PM
Default Re: I have a problem with my Clutch! Help (JdmFront619)
anyone?
Old Oct 26, 2003 | 05:45 PM
Loveless's Avatar
clutch jitter is will occur on new clutches, wait for 100miles and see how it goees
Old Oct 26, 2003 | 05:48 PM
Default Re: I have a problem with my Clutch! Help (Loveless)
that **** was rattling before I installed the new clutch also. I thought if I change the clutch, mayb that **** will shut up.
Thanks for the reply.....need to solve this **** fast.
Old Oct 27, 2003 | 03:52 AM
JimBlake's Avatar
Did you replace the throw-out bearing?
Old Oct 27, 2003 | 06:54 PM
Default Re: I have a problem with my Clutch! Help (JimBlake)
yup, replaced when I changed my clutch
Old Oct 28, 2003 | 03:57 AM
JimBlake's Avatar
It's possible the new T-O bearing is bad, but try this...
Engine running in neutral, clutch engaged (foot off the pedal). It'll be rattling, right? Quickly disengage the clutch (foot down) & listen.
A loose rattling T-O bearing will stop almost instantly. A noisy input shaft bearing in the transmission will take a couple seconds to stop because the input shaft takes a couple seconds to coast to a stop.
Old Oct 28, 2003 | 04:35 AM
IntEGNYC's Avatar
did you also replace the pressure plate and resurface/replace the flywheel? If its gripping, perhaps it needs adjustment.
Old Oct 28, 2003 | 12:25 PM
Default Re: (IntEGNYC)
we replaced everything, someone told me it might be the throttle bearing? he said that it might be worn out thats why it rattles.
thnx for the replies
0_civic_4
Aug 5, 2010 05:07 PM
Eddieman201
Dec 13, 2008 02:31 PM
renes
Nov 21, 2005 11:25 AM
tweekerz
Jul 11, 2005 01:28 PM
Flexer
Apr 16, 2004 07:43 AM
