Pressurized Valve Cover
Old Oct 26, 2003 | 05:17 PM
Muckman's Avatar
Moderator in Chief
Default Pressurized Valve Cover
Background: Rebuilt top end of 91 Integra LS B18A1. Bottom end is stock and untouched. Head machined, 3 angle valve job. Head vaccum tests perfect. Good compression and leakdown numbers.
The car starts and idles fine. At first there was a large amount of smoke coming from the engine, mostly the head area. I removed the oil cap from the valve cover and alot of smoke came out. I believe it was burning **** off because the amount of smoke went away after time. However the air coming from the oil cap hole was slightly pressurized, felt about the same as the muffler feels at idle. When it was real smokey I could see it shoot out of the oil cap hole.
This cant be normal. Any idea of what may be causing this?
Old Oct 27, 2003 | 07:37 PM
dirty_d_cx's Avatar
Default Re: Pressurized Valve Cover (Muckman)
have you ever noticed that there is a hose that comes from your intake to your valve cover. The air in your intake is moving which creates pressure in the little tube which in turn makes air flow into your valve cover
thus pressurized valve cover
i dont mean to seem like a smartass
Old Oct 27, 2003 | 07:58 PM
mmuller's Avatar
Mad Scientist
Default Re: Pressurized Valve Cover (dirty_d_cx)
when you put your hand over the oil hole it always shoots out air like that
Old Oct 27, 2003 | 08:44 PM
mycivicstoo(s)low's Avatar
Default Re: Pressurized Valve Cover (mmuller)
Yep, that's normal.
Old Oct 27, 2003 | 09:33 PM
Muckman's Avatar
Moderator in Chief
Default Re: Pressurized Valve Cover (mycivicstoo(s)low)
Ok wasnt sure how much is normal. Bleeder hose connected!
Smoke subsided after running the car longer. Must have been **** that needed to burn off.
Old Oct 27, 2003 | 09:42 PM
Like I said, I think it's fine. There's enough air coming out of there to feel it. And it feels, as you mentioned, similar to putting your hand behind the muffler. And a little smoke is ok, too. If it's gone, even better I suppose. As long as you have everything hooked up now, it sounds as though you'll be fine.
patrick4588
Jan 14, 2008 06:08 AM
Sprockets
Jan 3, 2006 07:30 AM
LSVTEC 91 Civic
Jul 30, 2005 12:47 PM
GruvyTune
Oct 22, 2001 01:29 PM
