B-Series swap into EK..need some help
Old Oct 26, 2003 | 01:51 PM
2000DX's Avatar
Default B-Series swap into EK..need some help
I'm swappin in a B16, can I use the stock Si Axles and the stock Si knuckle/spindle, arms?
Right now, the arm is like 1 inch from that damn hole that holds on the arm to the car. Are the axles too long? Arm too short? Whats wrong.....
this is the prob.
http://www.angelfire.com/ri/az...a.gif
Modified by 00 Hatch DX at 6:08 PM 10/26/2003
Old Oct 26, 2003 | 02:15 PM
blackhatchy's Avatar
Default Re: B-Series swap into EK..need some help (00 Hatch DX)
try searching.
better yet, take a look through the how-to thread at the top of the forum
/plug
Old Oct 26, 2003 | 02:20 PM
daklown's Avatar
Dat Dere Cell Tech
it should be working.
Old Oct 26, 2003 | 03:07 PM
2000DX's Avatar
Default Re: (daklown)
bump
Old Oct 26, 2003 | 03:16 PM
Newman's Avatar
New User
That bolt is for the lower control arm that attaches to the ball joint, underneath the knuckle. If the bolt isn't there, then the arm will push the entire knuckle assembly out, causing your axle to expand like that and pop out. Get that bolt in there first and impact that down and then put the suspension back together and axle in.
Old Oct 26, 2003 | 03:20 PM
2000DX's Avatar
Default Re: B-Series swap into EK..need some help (Newman)
Well if I put that lca in. Then I find it impossible to put the axle in. The knuckle just won't go out far enough for me to stick the axle in.
and what do you mean by expanding my axles?
Old Oct 26, 2003 | 03:34 PM
2000DX's Avatar
please guys...some help....i need to finish this by tonight so I will have a car to go to school tomorrow..
Old Oct 26, 2003 | 03:37 PM
JDMvtecDRAGSTA's Avatar
if the axles are off a 99-00 honda civic si then yeah everything should be fine
but if theyre single cam axles then no it wont work
Old Oct 26, 2003 | 04:06 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: B-Series swap into EK..need some help (Mr. Sparkle)
92 and up honda b series stuff are the same as the 94 and up integra b series stuff. except jdm itr hubs.
Old Oct 26, 2003 | 05:55 PM
2000DX's Avatar
Default Re: B-Series swap into EK..need some help (boostedcivicsir)
I'm using Si axles, arms, knuckle/spindle.....
1) If I put the LCA to the car...I can't connect the top to the control arm(?)
2) If I connect the control arm(?), I can't connect the LCA which is shown in the picture.
Both of those..I have the axles already in.
Any other ideas?
Old Oct 26, 2003 | 06:29 PM
2000DX's Avatar
sorry.....bump
Old Oct 27, 2003 | 06:03 AM
2000DX's Avatar
bump
Old Oct 27, 2003 | 06:08 AM
crxONcrack's Avatar
guess you are late for school.........but everything you have should be working fine. there is something that you are leaving out....slow down and make sure that you have everything bolted in correctly, and if you still cant get it together this afternoon, take some pics and post so we can see what is really wrong....
Old Oct 27, 2003 | 07:14 PM
2000DX's Avatar
Default Re: B-Series swap into EK..need some help (crxONcrack)
Everything is in. The guy that posted above said that my axles were expanded? Can I try to push it back or something?
Old Oct 27, 2003 | 08:21 PM
2000DX's Avatar
another bump....I just want the car to run..
I emailed Tom about this, I hope he can shine some light on it for me. *crosses fingers*
Old Oct 27, 2003 | 08:55 PM
salbaje's Avatar
looks like the bearings arent lined up and you pulled the boot out too far. try aligning them by playing around with the boot.
Old Oct 28, 2003 | 03:33 PM
2000DX's Avatar
Default Re: B-Series swap into EK..need some help (salbaje)
what do you mean I pulled my boot out too far? Would I push on the end of the axle to push it back in the boot? Please explain further on this.
Also today, I put the driver side axle in.....and when I started the car...the axle moved? I'm guessing the axle's weren't all the way in. (Only the driver side axle moved...the passenger side didn't move.)
Here are some pictures of more problems
In this picture here, I can't get that bar lined up w/ the camber kit/control arm? It just won't budge and let me push it to the balljoint.
Does the axle look like its in all the way?
Here's a view that might be better.
Does the shaft look likes its in all the way?
Old Oct 28, 2003 | 03:42 PM
99blackcivicSi's Avatar
Play with taht Boot and get it cruched back up man that is what your problem is the Joints are missalinged like that. You have everything right except for that little problem you got there it happens to everone don't worry.
Old Oct 28, 2003 | 03:47 PM
civicgsr93's Avatar
Default Re: B-Series swap into EK..need some help (99blackcivicSi)
That boot is streched alot, should be half of that size.
And for the first pictures, the bolt that you were having problem with, this should be one of the first to go in, then you insert your ball joint. But then again, I have no experience with a camber kit, but I don't think it's relevent in this situation.
Jonathan
Old Oct 28, 2003 | 03:52 PM
2000DX's Avatar
Default Re: B-Series swap into EK..need some help (civicgsr93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr93 &raquo;</TD></TR><TR><TD CLASS="quote">That boot is streched alot, should be half of that size.
Jonathan</TD></TR></TABLE>
Yea, in my last post above, I put the bolt in first, and I can't push the bar back up to the balljoint.
Also, How do I crunch it back up? Just push on the end real hard or what?
And the other prob...why did my driver side axle move and not the passenger when I started the car?
Old Jan 23, 2011 | 06:51 PM
jrod90dc2's Avatar
THat axle is a constant velocity axle (cv axle)it has three rollers that fit in slots inside a cup which is covered by a boot on eAch end. If it gums down too it take the boot off and insert it into the 3 slots in the cup and reinstall the boot with hose clamps. Then the Axle will compress into the correct length and everything should line up
Old Jan 23, 2011 | 06:53 PM
jrod90dc2's Avatar
Only one axle spins bcos u don't have a LSD equipped transmission.if u put it in reverse the other axle will spin
boostNjuice
Aug 15, 2011 09:03 AM
plaiskool
33
Aug 7, 2004 03:42 PM
guttedhatch
May 28, 2003 08:09 AM
XEF-9X
18
Aug 15, 2002 10:31 PM
Leo95SE
Jul 15, 2001 04:16 PM
