Bad O2 sensor symtoms?
Old Oct 26, 2003 | 11:49 AM
hybridEj6's Avatar
Default Bad O2 sensor symtoms?
Well before i calibrated my tps sensor my car was running really rich. Now that ive got it fixed it seems to have a really rough idle on warm up(around 800rpm) then when its warmed up it idles really low around 700rpm....and suposedly it smoke when i shift gears. Is this because of a faulty 02 sensor? Its throwing a code for a 02 sensor which is code one.
Old Oct 26, 2003 | 01:11 PM
80884's Avatar
Default Re: Bad O2 sensor symtoms? (ekhybrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhybrd &raquo;</TD></TR><TR><TD CLASS="quote">Its throwing a code for a 02 sensor which is code one.</TD></TR></TABLE>
that means o2 sensor is bad or wiring messed up or in some cases ecu is messd up, but mostly O2 sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhybrd &raquo;</TD></TR><TR><TD CLASS="quote">Is this because of a faulty 02 sensor? </TD></TR></TABLE>
you have a code for an O2 sensor, ^^^^^^ test the wiring if you want or buy a new sensor and see if it goes away.
i would guess that since you have a code that the sensor is bad, get a new one and go from there.
Old Oct 26, 2003 | 05:42 PM
hybridEj6's Avatar
Default Re: Bad O2 sensor symtoms? (80884)
would a faulty 02 sensor kill my gas meilage? cause my gas meilage is poop right now
Old Oct 26, 2003 | 05:46 PM
80884's Avatar
yes, it will kill your gas milage. not the proper air/fuel ratio so it will use more gas, run like ***, maybe act like it has a cam at idle, and give you code for O2 sensor. O2 sensors are some weird things to figure out, and the best thing to do with them is to replace them, that takes a lot of time out of figureing out if they are bad, cuz they usually are.
Old Oct 26, 2003 | 05:48 PM
80884's Avatar
what car, what engine? might have one for you.
Old Oct 26, 2003 | 05:53 PM
hybridEj6's Avatar
99dx coupe
94 jdm b18c
bma1818
12
Feb 3, 2007 10:45 AM
EGY8
Jul 27, 2006 12:49 PM
stephen_civic98
Dec 12, 2005 11:15 AM
93FastLs
Dec 15, 2004 03:48 AM
delguiner
Jul 8, 2004 08:32 AM
