ECU Question
Old Oct 26, 2003 | 09:12 AM
turbo90crx's Avatar
Default ECU Question
I have a 99 Si with a custom turbo kit, im using a 255 pump 450 injectors and a VAFC running 9 lbs of boost, now im getting a map code every once in a while and i have to reset the ECU from under the hood. i wanted to know if i could just put a toggle switch on the ECU fuse under the hood so i could just reset it from inside the car...could this be bad for the ECU??? any info will help....thank you...Chris L.
Old Oct 26, 2003 | 09:37 AM
80884's Avatar
Default Re: ECU Question (turbo90crx)
spend the money to keep the code from coming on, cuz no matter how many times you reset the ecu, the problem is still there.
Old Oct 26, 2003 | 09:49 AM
turbo90crx's Avatar
Default Re: ECU Question (80884)
what do u mean spend the money? on what?
Old Oct 26, 2003 | 11:58 AM
80884's Avatar
I don't know exactly what you need but the factory honda ecu and map sensor + boost do not go good together, my buddy had an integra that did the same thing, only his was at around 10-11psi, CEL would come on and car would not run right.
try to search about it and see what you get https://honda-tech.com/zerothread?id=528608 maybe try in the forced induction section.
again i don't have a fix for you, as i am not boosted, my map sensor works nice with my spray
b20ricepower
Engine Management and Tuning
Jun 4, 2011 03:00 PM
Drew Peacock
Dec 18, 2005 04:41 PM
turbo90crx
19
Oct 28, 2003 05:44 PM
turbo90crx
Oct 27, 2003 05:48 PM
kim_2_da_chee
May 30, 2003 06:18 PM
