My Compression test numbers. good?
Old Sep 4, 2001 | 04:53 PM
OneThirtyEight's Avatar
Default My Compression test numbers. good?
I had a compression check done today on my 97 LS motor with 90k miles, im putting a turbo on and wanted to chek engine condition. I hear these numbers are pretty good. what do u think? I know them all being equal is very good, is 165psi good for a LS motor though? This was done at a honda specialty shop, I didnt trust myself to do it right
1. 165
2. 165
3. 165
4. 165
Old Sep 4, 2001 | 05:00 PM
slowerthanu's Avatar
New User
Default Re: My Compression test numbers. good? (97blackteg)
That seems good for a car with a compression ratio like yours.
Old Sep 4, 2001 | 05:04 PM
Default Re: My Compression test numbers. good? (Teken)
They look very good indeed... What is the compression output for a new engine for your model year?? This would offer more insight to the overall health of the engine.
Thats what I was hoping to find out.
Old Sep 4, 2001 | 05:08 PM
AH THats what i meant, I was hoping to find out what compression is stock on my engine
Old Sep 4, 2001 | 05:11 PM
nutsack's Avatar
i got 180 across for all cylinders on my LS motor. only 9,000 miles on the motor.
Old Sep 4, 2001 | 05:19 PM
Default Re: My Compression test numbers. good? (*******)
ok, so my compression is a litle low (probably piston rings). BUt with 90k it should still be good for turbo rite?
Old Sep 4, 2001 | 05:44 PM
Josh's Avatar
New User
My 1990 LS came out at 190 psi in all 4 cylinders with 154k miles. Your compression numbers sound just fine to me. Its all dependent on the compression tester as well as your elevation. When you test your motor the big thing that you are looking for is your numbers do not vary too much between all the cylinders. And the numbers that you have are well within acceptable range. Your motor sounds to me like its perfectly healthy.
Old Sep 4, 2001 | 08:10 PM
quikrpm'z's Avatar
Default Re: My Compression test numbers. good? (Josh)
165 seems low.
Old Sep 4, 2001 | 09:51 PM
Mr. Softee's Avatar
Default Re: My Compression test numbers. good? (quikrpm1)
165 is fine... Ls's are typically 165-180 elevation and gobs of other factors make it vary a shitload.
-sam
Old Sep 4, 2001 | 09:59 PM
Tomakit's Avatar
Default Re: My Compression test numbers. good? (97lstegra)
after 15k of boost on my LS (~95k on the ticker now) i still get ~190's across the board.
also, if you are gonna be boosting, the mechanical upkeep on the car will be a lot greater than stock. the easiest thing to be able to do will be to do a compression check, it takes 15 minutes and their are any number of people on this board who would be willing to walk you through it. good luck.
Tom
Old Sep 4, 2001 | 11:06 PM
Akira-R's Avatar
Default Re: My Compression test numbers. good? (Tomakit)
How many times did you crank the engine? I konw the instructions i had said 5 but it should be morelike 8-10
--reid
Old Sep 5, 2001 | 04:48 AM
Civic Rs's Avatar
New User
Default Re: My Compression test numbers. good? (Akira-R)
I have 170 PSI in all four cylinder (B18B1 94).
Type 56
Engine Machining & Assembly
Aug 13, 2017 06:34 PM
lude98SH
Dec 18, 2006 04:39 PM
turbotime
Oct 1, 2005 08:46 AM
RACEPAK
Jun 12, 2004 01:29 PM
Phat Corolla
Aug 13, 2002 03:50 PM
