Car idles...then dies
Old Oct 24, 2003 | 09:33 PM
i's Avatar
i
Default Car idles...then dies
while sitting in the drive-through at Rally's today, my car just died out of nowhere. my car started just fine, but then maybe 10 mins later (it was a long wait) it died again! from the time i got to that drive through, and got home, my car probly died about 6 times! my car has died before, but my rpms would slowly get lower and lower, then die (and only once) what happened today was just ridiculous.
so anyway, i did a search and everyone keeps saying to check the compression, and one guy said he changed his idle using AFC hack. i was just wondering, how much would it cost to get my compression checked, and also is there a way to change my idle without Hondata/AFC hack?
(sorry this thread is so newbish, im still learning )
Old Oct 24, 2003 | 09:35 PM
solo2slocivic's Avatar
car? engine? trans? year?
Old Oct 24, 2003 | 09:36 PM
i's Avatar
i
Default Re: (solo2slocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo2slocivic &raquo;</TD></TR><TR><TD CLASS="quote">car? engine? trans? year?</TD></TR></TABLE>
whoops, sorry
-96 Civic (stock motor)
-standard
Old Oct 24, 2003 | 09:37 PM
common problem mine does it on occasion... base idle speed is out of adjustment...
do a search on adjusting idle
Old Oct 24, 2003 | 09:40 PM
i's Avatar
i
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo2slocivic &raquo;</TD></TR><TR><TD CLASS="quote">common problem mine does it on occasion... </TD></TR></TABLE>
yeah, so did mine, on OCCASION, but 6 times within maybe half an hour?! come on!
also, i forgot to mention that my car normally idles really low (anywhere from 500 to barely 100) could this be a fuel problem? i was thinking about changing my fuel filter, but not sure if that would help, or if i need to do something else...
Old Oct 24, 2003 | 09:50 PM
spend money if you want.... i would loose my job if i automatically threw parts in every drivability that comes through the shop with out proper diagnosis
Old Oct 24, 2003 | 10:06 PM
lo0nY's Avatar
same problem here.....ls/vtec with gsr tranny....Fuel Pressure at 42.....changed fuel pump and fuel filter......car with shut off when in neutral and idles between 100 to 1000rpms......anyone know what the problem could be?
Old Oct 25, 2003 | 07:11 AM
i's Avatar
i
Default Re: (lo0nY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lo0nY &raquo;</TD></TR><TR><TD CLASS="quote">same problem here.....ls/vtec with gsr tranny....Fuel Pressure at 42.....changed fuel pump and fuel filter......car with shut off when in neutral and idles between 100 to 1000rpms......anyone know what the problem could be?</TD></TR></TABLE>
when i did my search, i came across this post:
https://honda-tech.com/zerothread?id=640291
Old Oct 25, 2003 | 10:58 PM
lo0nY's Avatar
Default Re: (i)
anyone have any solutions?
JsSIR
Jan 11, 2013 11:42 AM
JBirch_97Prelude
Apr 1, 2007 08:52 PM
allmotorsi04
May 28, 2006 01:42 PM
Kwuaymaikrup
Sep 16, 2004 02:20 AM
mattL
Dec 11, 2002 10:08 AM
