Eagle 4340 H-beams and CTR Pistons
Old Oct 24, 2003 | 09:28 PM
djickabod's Avatar
Default Eagle 4340 H-beams and CTR Pistons
I was told that the CTR pistons will NOT fit on the Eagle rods. Have any of you been told this.
Old Oct 24, 2003 | 11:19 PM
hybrid_KJ's Avatar
Default Re: Eagle 4340 H-beams and CTR Pistons (djickabod)
The sadles on the piston where the small end of the rod go would need to be enlarged and you'd need to get slots machined into the pistons so you can use a snap ring to secure the wrist pin like aftermarket pistons. You'd be alot better off buying a set of Wisecos.
If you don't machine in the slots for the snap rings then the wrist pins will walk themselves right in to the cylinder sleeve and destroy a whole motor. I've seen this with my own eyes. Trust me and either run the eagles with aftermarket pistons or run the ctrs with stock rods.
Old Oct 25, 2003 | 05:27 AM
djickabod's Avatar
How much are a set of Wiseco pistons and what would be a good set? I was want 12:1cr.
Old Oct 25, 2003 | 06:24 AM
djickabod's Avatar
Well I believe I will be selling the CTR Pistons,Rings, and Wrist Pins to the first with $300 and shipping.
Old Oct 26, 2003 | 06:47 AM
SupaFly_Honda's Avatar
thank goodness I read this before doing my purchasing. Does anyone know if the JDM ITR pistons will fit onto the eagle rods?
Old Oct 26, 2003 | 07:55 AM
DVS_EF's Avatar
Default Re: Eagle 4340 H-beams and CTR Pistons (SupaFly_Honda)
i think it's the same as the ctr...
Old Oct 26, 2003 | 08:18 AM
function83's Avatar
Default Re: Eagle 4340 H-beams and CTR Pistons (dvsEF)
i dont see why you need aftermarket rods.
just get your stock ones shot peened.
Old Oct 26, 2003 | 10:30 AM
djickabod's Avatar
Default Re: Eagle 4340 H-beams and CTR Pistons (djhatch)
_______
Will you please explain what Shot Peened? This is my first build and Im still learning.
Old Oct 26, 2003 | 12:07 PM
BLK JDM's Avatar
Shot peening is a process used to strengthen the material and basically the rods become stronger. It'll be cheaper to shot peen the rods than selling your CTR stuff and buying aftermarket pistons and rods.
You don't need high performance, aftermarket rods when only using CTR stuff. Get ITR rods or shot peen your stocks. It'll be a lot cheaper.
ZCSp0ngeR
10
Mar 2, 2009 08:48 PM
jdmkidd23
Apr 23, 2008 04:21 AM
Spec R_GSR
May 12, 2007 07:01 AM
vtec69
Aug 10, 2004 08:25 AM
JDMlyfestyle
Mar 8, 2004 03:01 PM
