MUGEN Head Gasket and Compression
I installed the MUGEN head gasket on my R and I am getting great compression. I am using 93 Octane.
Cylinder1 - 245 Cylinder2 - 245 Cylinder3 - 255 Cylinder4 - 245
[Modified by ITR-Animal, 12:12 PM 9/4/2001]
Actually it was just a coinsidence, I did a compression check on my car this weekend and I wanted to post the numbers. I can't tell you if it made a difference because I installed a bunch off stuff all together. I have to tune and Dyno the car. I think the gasket will make a difference once I install some Toda Cams.
[Modified by ITR-Animal, 12:25 PM 9/4/2001]
Quick Questions...
Is there a way to calculate your actual compression rate from those numbers so that you know XX:1?
Also, doesn't the Mugen Headgasket create some kind of clearance issue with teh Toda Cams since the lobes is so much larger?
TIA
TIA
DC5ftmfw
May 20, 2006 01:49 PM
