swapped in SI tranny..cant shift
Old Oct 23, 2003 | 11:49 PM
GayHatch's Avatar
Default swapped in SI tranny..cant shift
i have a gsr eg hatch and i killed the tranny so i swapped in a 99 si trans but now when the pin goes through the linkage the shifter is cocked fully to the plastic on the driver side....any way to fix this?
Old Oct 23, 2003 | 11:52 PM
mycivicstoo(s)low's Avatar
Default Re: swapped in SI tranny..cant shift (GayHatch)
What shift linkage did you use?
Old Oct 23, 2003 | 11:53 PM
GayHatch's Avatar
Default Re: swapped in SI tranny..cant shift (mycivicstoo(s)low)
the stock gsr....dont tell me i need an SI linkage
Old Oct 23, 2003 | 11:56 PM
I won't tell you that, because I'm not sure. But it sounds like that may be it.
Old Oct 24, 2003 | 12:01 AM
Sprfreek's Avatar
without looking under the car or seeing it .. a pissability to try if it is the linkage is put the linkage on take out the pin put the shifter so it at a normal position .. if nothing is binding ... then you can possibly drill a hole through the end to amke it line up correctly
Old Oct 24, 2003 | 12:34 AM
Downey's Avatar
no, u dont need the Si linkage. any b-series linkage will work. post a pic of what it looks like. is there anyway u can line it up.
Old Oct 24, 2003 | 12:46 AM
mister2racer's Avatar
maybe you have the bars crossed over each other or something wierd?
Old Oct 24, 2003 | 04:33 AM
monicle's Avatar
Old Oct 24, 2003 | 05:44 AM
GayHatch's Avatar
^unfortunatly thats what i was thinking
Old Oct 24, 2003 | 06:22 AM
GayHatch's Avatar
further evaluation of the situation:
i looked at the gsr tranny and it seems that the pinhole on the tranny is straight down, while the pinholehole on the si tranny i just put in is a bit off to the passnger side
Old Oct 24, 2003 | 07:32 AM
shorty0o29's Avatar
Default Re: (GayHatch)
ttt
Old Oct 24, 2003 | 07:59 AM
DUCK COMMANDER's Avatar
Default Re: (shorty0o29)
it should be a direct swap. Look at it again 1 part at a time and make sure its put to gether the right way. If you dont know the right way, then try different things switch things upside down, etc. And if not improvise using physical force
Old Oct 24, 2003 | 10:36 AM
GayHatch's Avatar
Default Re: (DUCK COMMANDER)
im thinking that i would need to bend the peice of the linkage that goes onto the actual shifter attached the tranny, but it would be more of a rotation thing, then bending it any one way
Old Oct 24, 2003 | 10:49 AM
civicboisi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GayHatch &raquo;</TD></TR><TR><TD CLASS="quote">im thinking that i would need to bend the peice of the linkage that goes onto the actual shifter attached the tranny, but it would be more of a rotation thing, then bending it any one way</TD></TR></TABLE>
Bending a shift linkage isn't always good. I've heard horror stories bout this. Someone correct me if i'm wrong.
Old Oct 24, 2003 | 10:50 AM
GayHatch's Avatar
Default Re: (civicboisi)
not sure its so much bending now really as it is rotating, its the brass peice that goes onto the trany that needs to be spun clockwise like 2mm for it to go on straight
bwfisherman09
Transmission & Drivetrain
Oct 12, 2012 05:35 PM
8Gomer9
Mid-Atlantic (Sales)
17
Aug 5, 2009 10:48 AM
Totall Insane
Jul 7, 2006 09:43 AM
mugen97ek
Jun 2, 2005 08:53 AM
turbo Si
Apr 20, 2003 06:19 AM
