1way valve on a FPR vacuum line?
Old Oct 23, 2003 | 05:02 PM
iMPoRT GeeK's Avatar
Default 1way valve on a FPR vacuum line?
Hey i'm new on here so take an easy on me... this is what i go... Bubble back with USDM GSR, I/E, 65shot Dry ZEX.
So heres the question.. I bought the car with the swap already and this is the weird thing.. on the vacuum line that goes from the FPR to the intake, there was a 1 way valve Tee'ed into the line... I dont know why??? and when i installed the ZEX dry kit I removed the 1way valve because with the zex kit u have to have a vacuum line from the FPR into the ZEX "brain" and out to the intake...
is that 1 way valve there for any reason? i mean does it do anything?
also ideling is at 1300-1400RPM and the CEL on for Coolent Temp. sensor. I got the CTS, just didnt have time to install it yet.. but is the high idel because of the CTS? or is it something else???
Please let me know...
Thanks...
Old Oct 24, 2003 | 03:39 AM
JimBlake's Avatar
Default Re: 1way valve on a FPR vacuum line? (iMPoRT GeeK)
I don't think that check valve is supposed to be there. My GS-R doesn't have one. Which way is it oriented? You want your fuel pressure to track your manifold pressure, & the check valve prevents it from doing that.
CTS can cause your high idle. Other things can cause it, too. After you put in your new CTS you'll know...
thirdrail
Suspension & Brakes
Feb 22, 2009 04:32 PM
1baddcivicsi
Aug 24, 2006 09:28 PM
afterburners
Jun 10, 2004 08:44 PM
4gCRX
May 9, 2004 04:37 AM
Tyson
18
Nov 4, 2003 05:41 PM
