Head Build
Old Oct 23, 2003 | 06:34 PM
[ iLL ] iNt3GrA's Avatar
Default Head Build
alright i have a 99 Gsr and im looking to build the head. Just seeing if any1 has used some of these parts and what they think of them or whats better ty.
Ferra Valves
Skunk 2 B cams. cam gears, retainers and springs
i know that todaB's are better but they cost more $$
and what should i do to the bottem end and also whats a good fuel pressure reg?
thanks
Old Oct 23, 2003 | 06:54 PM
-iLLuZioN-B18C1's Avatar
Default Re: Head Build ([ iLL ] iNt3GrA)
try searching around ef-1.com
IMO they got some good stuff
Old Oct 23, 2003 | 06:55 PM
patdemps's Avatar
Im not sure if I have ever heard of Skunk2 B Cams. I think your talking about Skunk2 Stage one or stage 2 camshafts. If your getting these cams and want to get the max out of them, then yes the valves, retainers and springs are a good idea. Also, cam gears are always beneficial for dyno tuning.
patdemps's Avatar
Default Re: Head Build (patdemps)
Do you have any other work done to your car?
Old Oct 23, 2003 | 07:00 PM
yeah i have a AEM v2, skunk2 intake manifold, dc 4-1 "type-R" headers, no cat (way 2 loud), apexi n1, obd1 gsr ecu (not chiped yet), and a apexi V-afc.
yeah i ment stage 2 mixed it up with the toda b's
Old Oct 23, 2003 | 07:39 PM
patdemps's Avatar
Default Re: ([ iLL ] iNt3GrA)
You have a pretty good setup going. So if you really want power then yes skunk2 stage 1 or 2 would be beneficial to your setup. I don't know if all those parts are going to coexist and work well with each other but thats another thing. You may want to seriously consider getting some headwork done. A p n p or anything to open up the air flow. You could consider some tranny upgrades too....
Old Oct 24, 2003 | 03:56 AM
Gerhard_001's Avatar
Research befor doing anything. The key to a really fast car is how much air and fuel your head can flow, choose parts wisely. Fuel system upgrades should not be a consideration until you have the power to where it is required, otherwise it is overkill and could hurt performance.
Romo Pyro
Jun 2, 2008 01:46 PM
gsr_hatchback
Apr 11, 2005 07:37 PM
CandyRedHatch
18
Feb 24, 2004 03:23 PM
95integrags-r
May 6, 2002 12:14 AM
